more yj to tj axle conversion questions - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 9th, 2008, 09:52 PM   #1
scorpiansniper
engine / paint tech
scorpiansniper's Avatar
Send a message via AIM to scorpiansniper
Default more yj to tj axle conversion questions
in my previous questions ive cleared up the the tj axle and drive shaft should mount right to and in the yj axle but i also heard that they use different u joint thus having a bigger stub shaft so would that mean i need a different hub too to fit the bigger stub shaft. im looking for peoples opinions that did this upgrade was there any problems ect. also was they a couple different kinds of yj shaft cause i was looking on ebay and some of them where made to the year of the vehicle which didnt cover all tj's so there might be more than one kind. And just to clear this up the tj driveshaft a direct fit too right.
scorpiansniper is offline   Reply With Quote
Old January 9th, 2008, 10:20 PM   #2
Tie Dyed
O.G.
Tie Dyed's Avatar
Send a message via AIM to Tie Dyed
Okay, I am going to try here. I am not sure completely wtf you are talking about, but I will try to make sense of your questions.
It sounds like you are talking about the front axel shafts here. To get rid of the vac. axel shaft, you will need a new oil seal in the diff for the long side. The new shaft will fit right into place. TJ, and later XJ's use a stronger ujoint in the axel shaft. You do not have to change your hubs.
A TJ rear drive shaft will not fit a YJ, unless *I believe* you have the tcase out of the TJ. The tailshafts are different, and the rear drive shaft is a different length.
A TJ front will fit a YJ, but you will need to change the front output yoke on the tcase, if keeping the tcase from the YJ.
A TJ axel shaft swap is an easy upgrade for YJ's to get rid of the 2-piece front axelshaft. As for the rest, the axels are different because of abs.
2000 XJ with a 3 inch body lift
Tie Dyed is offline   Reply With Quote
Old January 10th, 2008, 08:28 AM   #3
kickstand
circling the drain
kickstand's Avatar
any idea on part number for the long side seal?
Thanks.
Old January 10th, 2008, 10:52 AM   #4
jeeptjpaul
jeeptjpaul's Avatar
Not all TJ axle shafts have the 297 u joint. Some have the 260's. Unless you find the 297 (larger) u joint axle shafts, this would not really be an upgrade for a YJ. You'd get rid of the disconnect, but not gain much shaft strength with the same small u joint.
jeeptjpaul is offline   Reply With Quote
Old January 10th, 2008, 11:51 AM   #5
kickstand
circling the drain
kickstand's Avatar
I've never seen a tj with the small u joints, can you enlighten me as to which ones had the small u joints so I can avoid?
Old January 10th, 2008, 03:24 PM   #6
scorpiansniper
engine / paint tech
that makes sense but are the stub shafts that come with the tj axles bigger cause if they are they wouldnt fit would they
Old January 10th, 2008, 07:15 PM   #7
Tie Dyed
O.G.
Tie Dyed's Avatar
no
Page generated in 0.27064 seconds with 44 queries
