track bar design - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 9th, 2008, 08:36 PM   #1
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Default track bar design
Any reason way 1.25 X .281" Wall DOM Tubing wouldn't be strong enough for a track bar? I shouldn't need to put any bends in it. Kind of having a brain fart today.
Useing a 3/4-16 heim at axle end and a fixed small RE joint at the frame. Or would a bushing at the axle end be better?
98 XJ D30 not that it matters.
Old January 9th, 2008, 08:59 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
I used 1 3/8" with around 1/4" wall so it should be fine.
I would use a bushing.
Old January 10th, 2008, 06:50 AM   #3
95geo
newbie
95geo's Avatar
.281" wall is plenty. a track bar is (should be unless it hits things) loaded with push/pull forces only, as long as it doesnt buckle under the loads then it is sufficient. if you can I would go with 1.5x.120 to save some weight... it will resist bending more than a a smaller diameter tube.
in a nut shell a smaller tube with a heavier wall will resist denting but will bend easier than a larger diameter tube with a thinner wall that will dent easier.
it might be a wash by the time you put the inserts in for the 3/4-16 though....
Old January 10th, 2008, 07:10 AM   #4
jeepnxj96
jeepnxj96's Avatar
1.25x.281 will be fine, if you try using 1.5 you will have issues getting it to fit in the axle end of a d30. as for bushing over a heim?, just depends on whether you mind a little more noise transfer. the bushing absorbs more noise and vibration than a heim. but since you are building it yourself the heim is way easier
Old January 10th, 2008, 04:27 PM   #5
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
True.
I really don't want to use a insert if I don't have to. That's why I was thinking about the 1.25" .281" wall. Since it's the right ID for a 3/4-16 NF tap.
Old January 10th, 2008, 04:31 PM   #6
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
My LCA's are Heims at the axle. The track bar bracket is over the top of the axle, I have more clearance than stock. Going to use the lower of the two holes.
Old January 12th, 2008, 01:32 PM   #7
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
I'm 99% sure I'm going to use a 2" Johnny Joint with 3/4-16 NF stud at the frame and a stock type bushing at the axle end. For the bar 1.50" 0.120" wall tube and a threaded insert. Sound good before I order the stuff?
Old January 12th, 2008, 03:50 PM   #8
95geo
newbie
95geo's Avatar
i dont like the 7/16 bolt on the 2" JJ it'll probably get the job done though.....
your call.
Old January 12th, 2008, 06:00 PM   #9
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
your call.
The grease bolt is extra and I won't be useing it. Just a plain old grade 8 7/16.
Page generated in 0.29304 seconds with 50 queries
