what do you guys think about this bender? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 8th, 2008, 02:01 PM   #1
busyfixin
Balls Deep
busyfixin's Avatar
Default what do you guys think about this bender?
i was looking for a new rotory table the other day and came across this bender in the enco catalog, what do you guys think?
http://www.use-enco.com/CGI/INPDFF?P...MITEM=890-0434
its actually on sale for 1600.
i dont know if i would actually get this one, or build my own very similar. it would be really easy to build one like it, using the cheap hydraulic bottle jack style as a base component, since it looks like its basically the same thing, just sideways with a ram instead of a jack. also, what is the difference in dies from the cheap hydraulic style to the more expensive ones? i know the cheap ones are cast, and the others may be machined, but what effect does it have on actual use?
should i just get a pro-tools type bender?
busyfixin is online now   Reply With Quote
Old January 8th, 2008, 02:03 PM   #2
beejers
always building
beejers's Avatar
f-in junk. just like a pipe bender. it is a pipe bender.
beejers is offline   Reply With Quote
Old January 8th, 2008, 02:53 PM   #3
Kawierider
Kawierider's Avatar
It would go buy a harbor freight one for 80 bucks and call it a day.
Old January 8th, 2008, 03:00 PM   #4
TopHeavy
Yikes!
TopHeavy's Avatar
beejers' quote still applies:
Buy My CJ7
TopHeavy is offline   Reply With Quote
Old January 8th, 2008, 03:14 PM   #5
busyfixin
Balls Deep
busyfixin's Avatar
thats what i thought. just thought i would ask.
Old January 8th, 2008, 04:11 PM   #6
Cooter21
Im Rick James Bitch
Cooter21's Avatar
For that price Buy a JD Square with the hydraulic attachment. Nothing beats a JD for the price. There is a difference between Pipe and tubing. good luck.
http://www.jd2.com/
Cooter21 is offline   Reply With Quote
Old January 8th, 2008, 04:25 PM   #7
95geo
newbie
95geo's Avatar
that bender is junk.
the bender is cheap, the dies are expensive.
Old January 8th, 2008, 04:40 PM   #8
Cooter21
Im Rick James Bitch
Cooter21's Avatar
what is so cheap about the jd bender? I have had mine for 5 years and I have never had an issue with it. What do you suggest is a superior bender under 1800 dollars for a project hobbiest?
Old January 8th, 2008, 05:36 PM   #9
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
Ummm I think he was responding to the original post...
As for the JD bender I can't comment. I know there is cheaper.
Old January 8th, 2008, 05:52 PM   #10
95geo
newbie
95geo's Avatar
yes, I was referring to the original post.
nothing wrong with a jd squared.
I own a protools 105hd with a home brewed hydro setup. the next step from there is an ercolina for about $5k
Old January 8th, 2008, 06:05 PM   #11
busyfixin
Balls Deep
busyfixin's Avatar
i know there is a difference between pipe and tubing. i also figured that bender style was lame, but it looked easy to build cheap, so i thought i would ask. im sick of borrowing benders, and hadnt seen that one before. maybe ill just copy a 105 and build it myself.
Old January 8th, 2008, 07:21 PM   #12
Motor Slut
Motor Slut's Avatar
here's the cheap alternative http://www.midamericanonline.com/tubing_benders.html
You want a bender that is pulling the tube over the die not just mashing it in there.
Old January 8th, 2008, 07:57 PM   #13
sodapop
Support the Sport!
sodapop's Avatar
If you have access to CAD and the type of tools to make the parts, here is a link to a free CAD drawing of a manual tubing bender.
http://www.trailslesstraveled.com/re...tubing-bender/
Old January 8th, 2008, 11:45 PM   #14
FORD FLARESIDE
just hockey
FORD FLARESIDE's Avatar
This is the one I'm looking at:
http://www.mtechsupply.com/view_page...ers&prodid=184
Old January 8th, 2008, 11:49 PM   #15
busyfixin
Balls Deep
busyfixin's Avatar
thanks!
Old January 9th, 2008, 12:08 AM   #16
busyfixin
Balls Deep
busyfixin's Avatar
what is the difference between the model 3, and the pro 105?
Old January 9th, 2008, 12:11 AM   #17
FORD FLARESIDE
just hockey
I think the 105 is just a better quality model...........
Old February 9th, 2008, 11:49 AM   #18
LAWNMAN323
MOWUOVR
LAWNMAN323's Avatar
You guys seen the "got trikes" benders on pirate? Air over hydro for an awesome price, you buy the plans and build it yourself. Pretty sure this is the way I will go.
LAWNMAN323 is offline   Reply With Quote
Old March 2nd, 2008, 05:06 PM   #19
aimmotorsports
aimmotorsports's Avatar
have a link to the page?
aimmotorsports is offline   Reply With Quote
Old March 13th, 2008, 09:51 AM   #20
russellmn
I built my own based off of a Pro Tools die. Used 1" for the arms and a HF air over ram for hydro.
russellmn is offline   Reply With Quote
Page generated in 0.93515 seconds with 83 queries
