Smith Shielding Gas Regulator and Hobart Wire, New - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 7th, 2008, 05:25 PM   #1
jeepxj2007
Send a message via AIM to jeepxj2007
Default Smith Shielding Gas Regulator and Hobart Wire, New
This is a Smith shielding gas regulator. It is brand new in the box, comes with everything in the picture including the spool of Hobart solid core wire. I believe this is the 30 series regulator, everything is identical to the picture and the description on other web sites. This is brand new, and hasn't been used. It came with my Miller welder, and I am only going to use flux cored wire. The item number on the box is Smith 221037, so I believe it is the 30 series because of the last two numbers, and looks identical in other pictures and has all of the same numbers. On the gauges it reads from 0-4000 inlet pressure, and on the output it goes from 0-50 cfh. This gauge is for use with argon, or argon/co2 mix, but not just a straight co2 gas. I don't know a whole lot about this gauge but if you have any questions, I will try to awnser them to the best of my knowledge. $60 to your door, or $50 if you pick it up.
jeepxj2007 is offline   Reply With Quote
Old January 7th, 2008, 05:58 PM   #2
Searchin4acj
Got Sand???
Searchin4acj's Avatar
Send a message via AIM to Searchin4acj
you have the stuff on the inside of the welder, if so i am very interested, looking to convert over my handler 125
Searchin4acj is offline   Reply With Quote
Old January 7th, 2008, 07:04 PM   #3
jeepxj2007
probably, I just got it for christmas, if I can remove it without damaging my welder it will come with it.
Old January 7th, 2008, 07:13 PM   #4
jeepxj2007
I just checked it, it looks like the hookup is part of the welder and I don't want to ruin it, I have a threaded part on the back where the hose screws in, and down by the drive role and clear tube connects which looks like it feeds the gas down into the wire, Im not 100%, but thats what it looks like, so I cant get the welder guts out with the sale, just the stuff in the picture.
Old January 7th, 2008, 11:43 PM   #5
Searchin4acj
Got Sand???
can i get some pics
Old January 8th, 2008, 10:08 PM   #6
jeepxj2007
yeah, I'll snap some for you tomorrow
Page generated in 0.17763 seconds with 41 queries
