laptop help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 5th, 2008, 05:36 PM   #1
Bishop
Bishop's Avatar
Default laptop help
just got a friends laptop (Dell XPS M140) and when it gets warm the fan witth kick on for 2 seconds then off for like 3 or 4 seconds. and comtineus to do so.
is this normal or is there somthing that needs to be replaced...
this is my first laptop so im not too familar with them. or is there a setting i can change to affect when the fan shuts on and off??
Old January 5th, 2008, 05:50 PM   #2
TechJeeper
Formerly "Gr8archer"
TechJeeper's Avatar
Send a message via AIM to TechJeeper
check out a program called speedfan, http://www.almico.com/speedfan.php and use it to control the fan if you want.
TechJeeper is offline   Reply With Quote
Old January 5th, 2008, 05:59 PM   #3
Bishop
Bishop's Avatar
will do thank you very much!!
Old January 5th, 2008, 06:14 PM   #4
Bishop
Bishop's Avatar
man that program is confusing
Old January 5th, 2008, 06:21 PM   #5
BMFmike
meh.
BMFmike's Avatar
No kidding, I cant get my VAIO to stop running the fan so I got that program... I have no idea what the hell to do.
Old January 5th, 2008, 09:00 PM   #6
mooseracing
Stuck like a MoFo
mooseracing's Avatar
Send a message via AIM to mooseracing
before you go adjusting the fan, there might be a reason its going on and off. If its working properly it should work just like an e-fan in our vehicle.
how about a screen shot of the temps from speedfan, and is it recognizing your board correctly?
I would leave the settings to manual until you figure out if its actually getting to warm. It could need a good cleanign with some compressed air. If you do clean it, use something to hold the fans, like a toothpick. You can spin them too fast. I've seen it happen many times in a laptop.
mooseracing is offline   Reply With Quote
Old January 5th, 2008, 10:02 PM   #7
BMFmike
meh.
BMFmike's Avatar
47* C
Edit: 57 Degrees Celsius
Old January 6th, 2008, 04:03 AM   #8
Bishop
Bishop's Avatar
its reading 102*F
Old January 6th, 2008, 05:51 AM   #9
Bishop
Bishop's Avatar
http://www.diefer.de/i8kfan/index.html
i found this to be much more user friendly
Old January 6th, 2008, 09:11 AM   #10
Hackfabrication
Hack
Hackfabrication's Avatar
It's probably dirty inside. Take it apart and vacuum it out. My desktops get full of freakin' gunk and have to be cleaned internally 3-4 times a year. Mostly cat dander and carpet fibers. Cat's dead, but the carpet is still here.
Hackfabrication is offline   Reply With Quote
Old January 6th, 2008, 02:06 PM   #11
mooseracing
Stuck like a MoFo
Originally Posted by BMFmike View Post
47* C
If thats no load, ie just sitting in windows doing nothing, thats pretty high (57c). With that, i would want to see low 40's no load,maybe 50s with 100% load.
I would get the can of compressed air and go through all the vents. But like i said, use a toothpick to hold the fans or something small that fits in there, but don't push it to far.
If you're brave and want to take it apart you could do a better job cleaning but you may never get it together properly again.
wrifrocks2005 if you are reading 102, which google says is in the 30c range thats fine. When is your fan kicking on, is it at load or just sitting there doing nothing. When i mean nothing, there is no cpu utilization in task manager.
I know that dell is one of the smaller models, and the newer laptops have more of a blower fan, like what is in your furnace instead of the desktop style fans. edit: my mind got off track, anyway they seem like they are working harder or sound louder, but its designed that way.
Old January 6th, 2008, 10:29 PM   #12
Bishop
Bishop's Avatar
thats what i thought, because it didnt seem to hot at all. im not to concerned with it over heating it just how fast the fan will turn on then back of again so fast.
Page generated in 0.36921 seconds with 58 queries
