TBI wiring - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 5th, 2008, 02:46 AM   #1
A4X4SPIT
A4X4SPIT's Avatar
Default TBI wiring
I have a 1.3 tbi fuel injection intake & throttle body (samurai)& I have a wiring harness from a 1.6 8v tbi(tracker) that was in another rig the harness was modified so only a few power & ground wires were needed to power ecm. the wires on the tbis have the same plugs. Im wondering if I can use the 1.6 harness to make the 1.3 tbi work ?.
A4X4SPIT is offline   Reply With Quote
Old January 7th, 2008, 09:21 PM   #2
A4X4SPIT
A4X4SPIT's Avatar
I checked more into the wiring & there are slight differences so I am using a 1.6 tbi on the sami tbi manifold & the modified harness & I mounted the tracker in tank fuel pumpin the sami tank should be running soon
Old January 10th, 2008, 07:08 AM   #3
jimmyroyse
webwheeler
jimmyroyse's Avatar
just in case you don't have it.
downloads of the factory manuals including the tbi supplement;
http://www.suzukiinfo.com/
It has been a very long time since I looked at any of this, but I belive you will want to use the 1.6 manifold too. there are vacume passages in the bottom of the throttle body that don't match the 1.3 manifold.
jimmyroyse is offline   Reply With Quote
Old January 10th, 2008, 07:35 AM   #4
A4X4SPIT
A4X4SPIT's Avatar
I thought the manifolds both tbi looked the same had it running but it flooded out (in between starts) the fuel pump dosent shut off after 3 seconds like its suposed to this modified harness came out of a rig that worked sweet until the #4 conecting rod went thru the block Ive got to re check conections make sure I did not miss a ground or power conection.
Old January 10th, 2008, 07:39 AM   #5
jimmyroyse
webwheeler
jimmyroyse's Avatar
like I was saying, it's been a loonng time........
if it worked in the rig it came from then find out what computer they used. the plugs are the same but I am positve the pins were different between the 1.3 and the 1.6 computers.
Old January 10th, 2008, 05:06 PM   #6
A4X4SPIT
A4X4SPIT's Avatar
Im using the 1.6 harness /1.6 ecm /1.6 throttle body on the 1.3 tbi manifold which all worked on the 1.6 just gotta get some quality garage time so sort the fuel pump not turning off after 3 sec from power on
Old January 11th, 2008, 12:01 AM   #7
incogrhino
i pull out
incogrhino's Avatar
Does it ground threw the ecm like the GM ones?
incogrhino is offline   Reply With Quote
Old January 12th, 2008, 03:30 PM   #8
jimmyroyse
webwheeler
jimmyroyse's Avatar
I was looking at the wiring diagrams for the 1.6 & it looks like you may have a bad feul pump relay or a bad ground at the relay. hope that helps.
Old January 12th, 2008, 10:15 PM   #9
A4X4SPIT
A4X4SPIT's Avatar
I replaced the fuel pump relay and every thing seems to work had it running & drove it . It starts easy and dosent have the heasitation it used to it seems to be running a little rich I dont know about the o2 sensor and gotta try map sensor vacum line change we are farther ahead than aweek ago now its drivable
Old January 14th, 2008, 06:13 AM   #10
jimmyroyse
webwheeler
jimmyroyse's Avatar
O2 sensors are like $15.- at autozoners for the generic one. It made a huge difference in mine.
Page generated in 0.24167 seconds with 53 queries
