Vacum disc.. question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 3rd, 2008, 03:08 PM   #1
Theidt88
Boggers boy
Theidt88's Avatar
Send a message via AIM to Theidt88
Default Vacum disc.. question
Whats the best way to eliminate the vacum disco unit. Want to put a 1 peice shaft in from a zj, and where do i put this new seal? As an outer seal of the housing or what> thanks This is for a 93 YJ. Just pull the fork and guts out and put a plate over it and call it a day? any help would be appreciative!
Theidt88 is offline   Reply With Quote
Old January 5th, 2008, 02:46 PM   #2
Theidt88
Boggers boy
Theidt88's Avatar
Anyone>>????
Old January 5th, 2008, 05:03 PM   #3
Square-D
Administrator
Square-D's Avatar
There are a few good write ups on here for that question. I just tried the search to give you the threads. This is when I found out that the search SUCKS. Good luck.
Square-D is offline   Reply With Quote
Old January 5th, 2008, 05:11 PM   #4
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
i just put in a trac-lock pull cable
'09 "Sparkly Tan" Jeep Patriot
http://badges.fuelly.com/images/smallsig-us/306663.png
CLICK HERE TO GET RID OF ME
Originally Posted by PCK_4xCustoms View Post
cunt punt, it's like a reset switch for women.
sQUEAK003 is offline   Reply With Quote
Old January 5th, 2008, 11:15 PM   #5
sodapop
Support the Sport!
sodapop's Avatar
There's a seal that will fit into the Axle tueb next to the pumpkin but I don't know the number. Try PM'ing junk90xj or monkeyevil about it. They both have done this seal swap.
Here's a couple link s
http://greatlakes4x4.com/showthread.php?t=53154
http://www.greatlakes4x4.com/showthread.php?t=16655
Old January 5th, 2008, 11:17 PM   #6
sodapop
Support the Sport!
sodapop's Avatar
Oh and a better way to search is to use google and use this format... Forum search engines tend to suck
search term or terms space then site:which site to seach no spaces
like this (see below)
vacuum disconnect site:greatlakes4x4.com
Old January 6th, 2008, 02:42 PM   #7
Theidt88
Boggers boy
Theidt88's Avatar
thanks guys!
Page generated in 0.22213 seconds with 44 queries
