ok soo... after a very bad trip to the mounds and an engine later my truck runs but.. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 18th, 2006, 11:03 PM   #1
4x4inAllDay
Dodge Father-Ram Daughter
4x4inAllDay's Avatar
Send a message via AIM to 4x4inAllDay
Default ok soo... after a very bad trip to the mounds and an engine later my truck runs but..
its weird.. hopefully somebody can help me out
i got the donor motor to start up.. it idle's great actually.. it sounds good, no real noise, no smoke.. it seems to rev up good from what i know.. i did install the motor my self.. direct replacement of my original stock 5.9... cept i added accel coil, wires, cap rotor.. and hedders... so heres the problem
if i sit there and rev it up a couple times( not even to high it will conk out)
if i put it in gear and try to drive ( it will conk it out )
other than that it seems to idle for as long as i let her idle...
at one point ( this is a used motor already broken in) i held the brake to see if it would spin the tires (very smooth cement in the shop it should be easy) it did do that but a 2nd later conked out
HELP!
4x4inAllDay is offline   Reply With Quote
Old March 18th, 2006, 11:12 PM   #2
Monster4.0
Monster4.0's Avatar
Is you fuel pressure correct for your new motor?
Old March 18th, 2006, 11:17 PM   #3
4x4inAllDay
dunno? im using my old fuel rail and my old fuel injectors though....
Old March 19th, 2006, 01:56 AM   #4
noodles
give 'er sh*t ay?
noodles's Avatar
check the asd relay.. it would kill it. it turns off the fuel pump. but it sounds like yo uhave enought fuel pressure to run it at idle, btu when you rev it up you run out. might do a flow test and a pressure test on the fuel.
Old March 19th, 2006, 05:03 AM   #5
4x4inAllDay
ahh the brand new coil i bought for it was baaad!!
got another and she was all SET.. no frickin spark will do it!
Old March 19th, 2006, 04:43 PM   #6
SS
Bananarama!
SS's Avatar
I told you Accel coils had a very high failure rate
Yours was bad out of the box!
Should've just returned it and got an MSD
-Jer
Old March 19th, 2006, 05:03 PM   #7
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
x2
Nice custom title...
Old March 19th, 2006, 05:42 PM   #8
SS
Bananarama!
SS's Avatar
Originally Posted by GreaseMonkey
x2
I see you couldn't fit the "male" part in your own title
-Jer
Old March 20th, 2006, 10:20 AM   #9
noodles
give 'er sh*t ay?
noodles's Avatar
glad you got the truck running though
Page generated in 0.29861 seconds with 50 queries
