Light wiegth Trailer - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 3rd, 2008, 11:49 AM   #81
sodapop
Support the Sport!
sodapop's Avatar
Originally Posted by jmdzuk View Post
off P.
When I read this I thought, "What... off P."
Originally Posted by UP_ROKTOY View Post
most of those pictures are coming from www.pirate4x4.com its a message board similar to this one, have you seen it?
But then UP_ROKTOY was nice enough to post his link. Thank you very much, I hadn't been there before. That site, www.pirate4x4.com is effing amazing! Looks like it's been around along time, I wonder if that's were CC got his name idea from
If you google light weight trailers this what you get .Search Pirate and come up with something more applicable.Jeff
I tried but couldn't find nothing except people bitchin about "red stars" WTF is that all about????
Originally Posted by Roadhouse View Post
what a dick
Huh?? I think he was just trying to help me out...
:tonka:
Old January 25th, 2008, 02:08 PM   #82
Ran across rotozuks buildup thread, which has lots of ideas:
http://www.pirate4x4.com/forum/showthread.php?t=392230
He's towing his buggy behind his 4.3 V6 Astro quite happily. Might have the pic already posted, I can't see the pics in this thread at work, due to filters, so hope this isn't useless info.
Old January 25th, 2008, 04:27 PM   #83
The pics I see are a dune buggy on a T-trailer. Not the same thing.
Old January 25th, 2008, 05:19 PM   #84
88yj
collecting parts
88yj's Avatar
Send a message via AIM to 88yj
Follow the thread, he doesn't build a T-trailer. It actually turns out pretty well.
88yj is offline   Reply With Quote
Old January 25th, 2008, 06:24 PM   #85
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Earlier in this thread was a pictures of his setup.
Old January 25th, 2008, 07:10 PM   #86
its the build thread for this one:
There's good ideas in that thread, and good discussion. Its a tandem, so loading/balanace, and handling blowouts would be better than a single axle.
So, reading that thread, it towed well behind his V6 astro van. I would bet that on a standard deck 16 ft tandem, it'd be felt more. I definately like the idea of a 4000lb combined load behind a smaller tow vehicle.
How often are people blowing trailer tires, and why?
I would be interested to see how load range E 235/85/R16 highway rib truck tires would do on a trailer.
Old January 25th, 2008, 09:37 PM   #87
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
could you get a 16" trailer rim?
Old January 25th, 2008, 10:09 PM   #88
Sorry, I did a quick scan thru only looking for the pics. My bad.
Old January 26th, 2008, 08:08 AM   #89
I've seen trailers use 235/85R16s before. I think 7000 lb axles are usually 8 on 6.5.
I've always had the feeling that the majority of trailer tire failures that happen are due to poor maintenence and people banging their trailers into things like curbs, fences, etc. That, and people using cheap-o tires on their trailers, $40 specials or old car tires.
I haven't ever had a tire failure, per se. I once had a tire tire lose some tread (didn't lose air, but was thumping badly) on a construction trailer (back when I worked landscape for 3 years and pulled a trailer daily). Those trailers say daily use and the tires were old. I also damaged a sidewall once pulling out of my back yard (had bought a new trailer, didn't realize it was wider than the old one, and I clipped my chain link fence). I parked the rig in the driveway and replaced it with a new once, before continuing, though.
You just don't see people blowing tires on their tow rigs all the time, so why do people have problems on their trailers? low air pressure, scuffed sidwalls, improper loading? Are truck tires tougher, or to trailer tires see more damage?
I't d be kinda cool to design the trailer to have the same bolt pattern and tire size as your tow vehicle (if possible), so you'd have spare tires that could work for either vehicle.
Old January 26th, 2008, 08:45 AM   #90
KartRacer
Blowd up
KartRacer's Avatar
Dry rot.
Old January 28th, 2008, 02:41 AM   #91
busyfixin
Balls Deep
busyfixin's Avatar
i dont see where all these tire blowing ideas come from either, and even if the do blow all the time (i guess im just always lucky, having never blown one.) i dont see how everyone sees this as a horror storry. the trailer isnt going to do anything at all, except fall down about 6 inches on one side. you will then notice it and pull over to change it.
Old January 28th, 2008, 07:51 AM   #92
Well, depends on the load, and if your tow rig is pushed to its limits.
Any time i've been in a truck when one went, it was not really noticeable, to me as a passenger, except by visually seeing it was bad in the mirror.
Page generated in 0.40498 seconds with 59 queries
