Ford 8.8 Info - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 11th, 2005, 04:04 PM   #1
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Default Ford 8.8 Info
Cross referencing this here...
Figured I would post my links to 8.8 tech i have aquired, never made my own because these were more then sufficient. If people search I hope this will come up for them.
at a glance...
These are the codes you will need when out shopping for your 8.8
Axle tag codes:
3L73 = 3.73 LS
4 10 = 4.10 open
4L10 = 4.10 LS
and so on
Door codes:
43 Open 3200 3.08
41 Open 3200 3.27
42 Open 4.10
46 Open 3.73
45 Open 3200 3.55
D4 Limited Slip 3200 3.73
D2 Limited Slip 4.10
L73 Limited Slip 3.73
Here's all the specs, measurements, and misc crap about the 8.8 you'll ever want to know.
Ford 8.8 specs:
Weight (complete assembly w/ brakes etc.): 174 lb.
Axle shaft strength: 6,500 (lb. ft.)
Drivers side Ford brake hose #:F5TZ-2282-A
Passenger side brake hose #: XL2Z-2282-AA
Bolt size (U-joint flange to yoke) is: 12 x 1.75 x 30 mm
Driveshaft Flange: Spicer Part Number 2-2-1379
Measurements:
O.D. of tubes: 3.250".
Tube thickness: .250" (some are .188!)
Ring gear diameter: 8.800".
Ring gear bolts: 7/16" dia. (qty. 10).
Pinion diameter/splines: 1.625 / 30.
Axle shaft/splines: 1.320 / 31.
Rotor thickness (where it mounts to axle is .250").
Overall width 59.625" (the F8.8 is .950" narrower then a TJ Dana 35).
Hole diameter for ABS sensor in top of housing: .811".
Centerline of housing to C/L of pinion difference is 3.875" toward the P/S.
Pinion offset: P/S to C/L of Pinion, 27-3/4" (no rotor on axle), D/S to C/L of Pinion, 31-5/8" (no rotor on axle). (this measurement is 2.5" more offset to the P/S then a TJ Dana 35).
all taken from
http://members.cox.net/quanno/ford88.html
there are comparison pics to the D35 there as well
also www.stu-offroad.com has TONS of info... not just on 8.8 axles
Old January 19th, 2007, 01:38 AM   #2
nick_n_ii
nick_n_ii's Avatar
Send a message via Yahoo to nick_n_ii
That is some good reads.
nick_n_ii is offline   Reply With Quote
Old January 21st, 2007, 07:17 AM   #3
yogi
swampstomper & old fart
yogi's Avatar
8.8 bible good reading
http://www.jedi.com/obiwan/jeep/ford88.html
yogi is offline   Reply With Quote
Old January 22nd, 2007, 02:52 PM   #4
SolLess
08' Unlimited JK "X"
My personal favorite for 8.8 info
http://www.jeepsunlimited.com/forums...d.php?t=674123
SolLess is offline   Reply With Quote
Old May 24th, 2007, 07:29 PM   #5
Mongo
Mongo's Avatar
source for 8.8 flange
bigger u-joint (1310) 2-2-1369
smaller u-joint 2-2-1379
Weller Truck Parts
Grand Rapids
800-872-6697
Website wont do you any good just call and ask for sales.
$12.41 for 2-2-1369, the other should be close. + shipping.
Mongo is offline   Reply With Quote
Old October 29th, 2007, 03:59 PM   #6
JeepGenocide
JeepGenocide's Avatar
http://www.bc4x4.com/tech/2003/xj88/
one for xj's
JeepGenocide is offline   Reply With Quote
Old November 21st, 2007, 11:27 AM   #7
Trail-XJ
Bank Account Understands!
Trail-XJ's Avatar
thanx again!
Trail-XJ is offline   Reply With Quote
Old February 27th, 2008, 01:52 AM   #8
cham
Inconsistant at Best.
Now this is some great info to have.
cham is offline   Reply With Quote
Old March 31st, 2008, 04:33 PM   #9
Kawierider
Kawierider's Avatar
Originally Posted by JeepGenocide View Post
This link say that all charokees with the 8.25 rear end have the 1330 U-Joint.
This is not the case. You have the 1310. and need the 2-2-1369 part number
Old July 10th, 2008, 10:51 PM   #10
mean_greenEXJAY
YJ now
mean_greenEXJAY's Avatar
another word on the u-joint flange, the one off an early 90s explorer will work for the 1310 ujoint, it has a spicer p/n 2-2-671, I was unable to look up that number, but it did work.
Old October 28th, 2008, 03:17 AM   #11
busyfixin
Balls Deep
busyfixin's Avatar
you might want to note somewhere that this is for the explorer 8.8 (i think), and not the fullsize 8.8.
Old March 31st, 2009, 01:40 PM   #12
shifty_85
2 low for fat hoes
shifty_85's Avatar
Send a message via AIM to shifty_85 Send a message via MSN to shifty_85
good info on the 8.8 im kind of confuzed thoe. i have a 97 F-150 with an 8.8 and i jacked up the rear pig spun the tire once the drive shaft spun 3 n a half times. doesnt that mean 3.55's? but i also have LS because when i do break torques both tires spin.
shifty_85 is offline   Reply With Quote
Old April 13th, 2009, 10:48 PM   #13
dodger889
dodger889's Avatar
Here is a link for Ford rear ends that uses the tags on them.
http://www.fordification.com/rearends-ford01.htm
Might help someone that is looking for one out of a junk yard
Old August 11th, 2009, 02:09 PM   #14
coolgareray
NMU Trailcat Alumni
coolgareray's Avatar
just got a price today, the 1310 flange is $25 now but still not a bad price
coolgareray is offline   Reply With Quote
Old September 16th, 2010, 10:56 PM   #15
wally431
wally431's Avatar
I've got a quick question. Can I get a ring and pinion set of 5.38 gears for an 8.8? I can't seem to find them it goes from 5.13 to 5.71? I'd like to put a dana 44 up front and regear to 5.38s so I'm hoping someone can help me find gears for the 8.8. thanks
wally
wally431 is offline   Reply With Quote
Old March 19th, 2012, 06:48 PM   #16
Wramblerguy
Wramblerguy's Avatar
Is there a carrier size split like 3.73 and up or what?
Old March 19th, 2012, 07:56 PM   #17
jpr Jeremy
LS Powered
jpr Jeremy's Avatar
nope, the 8.8 doesn't have any carrier splits.
jpr Jeremy is offline   Reply With Quote
Old March 19th, 2012, 11:50 PM   #18
Wramblerguy
Thank you
Page generated in 0.45483 seconds with 77 queries
