1978 auto shift problem - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 29th, 2007, 03:21 PM   #1
72cj304
72cj304's Avatar
Default 1978 auto shift problem
it is a 1978 dodge 1/2 ton 2 wheel drive 318 with 727 trans did a motor swap to a 82 318 4bbl replaced rad and put trans cooler on problem is when you put in rev it is fine when you put it in drive it slips untill you hit the gas I was told that the kick down linkage may be the problem the trans was fine before the swap it has a edelbrock carb and I put the throttle lever kit on still no change I checked the fluid with the engine warm and running it is at the full line any infro would be great thanks
72cj304 is offline   Reply With Quote
Old December 29th, 2007, 04:06 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
yea sounds like you might have to adjust the kickdown linkage.
Page generated in 0.13700 seconds with 29 queries
