NP231 yoke replacement - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 18th, 2006, 09:39 AM   #1
hztd0m
hztd0m's Avatar
Default NP231 yoke replacement
I managed to bust one of the little tabs off the rear yoke of my np231 (the tab that holds the u-joint cap in) Anyone have one lieing around that they would sell me or do you happen to have a part number. I would take it off and bring it in the store with me but the jeep is my only mode of transport at the moment.
I'm located in lansing.
Thanks.
hztd0m is offline   Reply With Quote
Old March 18th, 2006, 11:48 AM   #2
SageJp
SageJp's Avatar
I'm confused, do you already have the slipyoke eliminater. If not, their shouldn't be a yoke on the rear of the t-case.
By the way, If you do have a sye, I have the yoke that came with my advance adapter sye. I never used that yoke, but I'm a ways from you.
SageJp is offline   Reply With Quote
Old March 18th, 2006, 02:11 PM   #3
junk90xj
ALLPRO AUTO
junk90xj's Avatar
pm to you
http://www.apalansing.com/
Old March 18th, 2006, 04:53 PM   #4
hztd0m
hztd0m's Avatar
I have a SYE so the rear of the t-case is now a fixed yoke. I could be wrong on the terminology. the rear of the t-case has the same end as the differential.
Old March 19th, 2006, 09:09 AM   #5
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
You most likely will have to get one from the manufacture of the SYE. They have yokes turned to there seals. So as a fix I would use an old ujoint and put it in the yoke. Push to the good side with a tab. And weld a washer onto the side that is broken off. I have done this as a trail fix to mine and many others. Most have never changed the yoke after that
Old March 19th, 2006, 12:11 PM   #6
SageJp
SageJp's Avatar
I've seen this done on alot of rigs, works great. In fact, I have a buddy that does this to all his yokes before they get the chance to break.
Old March 20th, 2006, 09:12 AM   #7
hztd0m
hztd0m's Avatar
Good call. That's what I'll do, thanks again for the help.
Page generated in 0.23302 seconds with 44 queries
