Heavy Duty Casters $20 per set of four - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 27th, 2007, 01:15 PM   #1
cornfed
I have an avatar. Yippee.
cornfed's Avatar
Default Heavy Duty Casters $20 per set of four
Whatever your needs, I'm sure I have a set of casters to fill them.
Paypal accepted, UPS and USPS shipping available. I can save you a couple bucks if I ship to a business address.
Cushion-Center Caster Rigid, 5" X 1-3/8" Nylon Wheel, 440# Cap
Cushion-Center Caster Swivel, 5" X 1-3/8" Nylon Wheel, Total Lock, 440#Cap
The swivel action is welded. Cut the weld to allow them to swivel.
LINK
LINK
cornfed is online now   Reply With Quote
Old December 28th, 2007, 01:25 AM   #2
Stan
I got a gold chain
Stan's Avatar
Which would be best suited for a YJ?
ttt
Stan is offline   Reply With Quote
Old December 28th, 2007, 01:32 AM   #3
sQUEAK003
Irish R&B Singer
sQUEAK003's Avatar
from the looks of your build thread.....its needs wheels.....go with these and get rid of thoose jack stands
'09 "Sparkly Tan" Jeep Patriot
http://badges.fuelly.com/images/smallsig-us/306663.png
CLICK HERE TO GET RID OF ME
Originally Posted by PCK_4xCustoms View Post
cunt punt, it's like a reset switch for women.
sQUEAK003 is offline   Reply With Quote
Old December 28th, 2007, 02:00 AM   #4
boggin-machine
boggin-machine's Avatar
would any of these be strong enough for a set of dollys to set cars on and move around in the garage?
Old December 28th, 2007, 08:12 AM   #5
howell_jeep
Last Free Man
howell_jeep's Avatar
Are you willing to seperate wheels and tires?
howell_jeep is offline   Reply With Quote
Old December 28th, 2007, 08:19 AM   #6
cornfed
cornfed's Avatar
Yes. Out of this bunch, I'd use the GD-60s. Each caster has a 550# rating, they have the lowest profile, and a screw brake. Get 16 of them and make for dollys each having a 2150# capacity (I knocked off 50# for materials in case you use 4x4 wood or mucho steel). The GD-60 is the only type in which I have enough quantity for a dolly set.
The other casters are perfect for shop carts, workbenches, the big ass buzz-box, etc.
Old December 28th, 2007, 08:21 AM   #7
cornfed
cornfed's Avatar
Yes, but only if I'm allowed to use your forehead as a tire spoon.
Old December 28th, 2007, 08:40 AM   #8
howell_jeep
Last Free Man
No thanks, I was looking to have them shipped.
Old December 28th, 2007, 08:51 AM   #9
cornfed
cornfed's Avatar
Which casters, how many, which zip code? Business or residential address?
Old December 28th, 2007, 09:02 AM   #10
howell_jeep
Last Free Man
Would like four that can support at least 1000# combined and all need to swivel and easy to roll around. Which do you recommend?
Old December 28th, 2007, 09:33 AM   #11
BAD
BAD's Avatar
how much for the dolly casters
BAD is offline   Reply With Quote
Old December 28th, 2007, 10:08 AM   #12
cornfed
cornfed's Avatar
Any of the casters will meet your needs as long you're rolling them on a hard surface. The "lightest" caster (4th from top) has ~300# each rating (IIRC).
What are you building? To select which is best for your application, you need to consider:
Mounting: do you prefer the flat plate or square stem?
Is the wheel diameter important? Taller wheels roll easer and provide more space under the frame.
Do you need brakes?
Old December 28th, 2007, 10:09 AM   #13
cornfed
cornfed's Avatar
$15/pair for all except the last set.
$25/pair for the last set/green poly over steel wheel.
Old December 28th, 2007, 09:05 PM   #14
BAD
BAD's Avatar
i mean for all 16 for dollys
Old January 20th, 2008, 11:12 AM   #15
cornfed
cornfed's Avatar
Bump. Price change. Now $20/4
Old January 21st, 2008, 09:42 PM   #16
JJOHN WAGOHN WAGJ
leadfoot
I need four casters that are rated to hold my jeep Ihave a lift I want to put them on which casters do you recommened I also would like to have some for my welding cart. thanks John 810 735 6593
JJOHN WAGOHN WAGJ is offline   Reply With Quote
Page generated in 0.39078 seconds with 71 queries
