"Overfilled" Diffs - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 26th, 2007, 11:34 AM   #1
DuffMan
Your Message Here
DuffMan's Avatar
Default "Overfilled" Diffs
I got (OK, won at Pig Gig ) a Solid diff cover for my yet-to-be-installed D44.
I see this (and other) aftermarket covers raise the fill plug to allow additional diff lube capacity.
The way I see it, a higher level of diff lube is going to run into the axle tubes down to the seals.
Is this a:
1) Good thing? (more lube = more lubrication/cooling and a given amount of impurities distributed across a larger volume of lube (...dilution is the solution to pollution...)
2) Bad thing? (lube sloshing around seals designed for a lower level of lube, aeration/foaming of lube as it sloshes about)
3) Neither good nor bad?
Theoretically it sounds good, but theoretically a bumblebee can't fly.
Thoughts?
Old December 26th, 2007, 11:58 AM   #2
xj nut
maxin out the 30
xj nut's Avatar
well from what i have put togheter , raised fill plugs do add more fluid to compensate for higher pinion angles. when you lift a vehicle the pinion changes, so the diff fluid levels shrink because of the angle. so all in all its just compensation.
hope i made sense and helped
xj nut is offline   Reply With Quote
Old December 26th, 2007, 12:10 PM   #3
Never had a problem with a higher dif level. Did it for the same reason, trying to lube the pinion bearings when tipped up.
Page generated in 0.21199 seconds with 32 queries
