dana 60 =dana 61 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 26th, 2007, 01:36 AM   #1
boggin-machine
boggin-machine's Avatar
Default dana 60 =dana 61
whats the difference between the two and how do i tell so i can order gears?
Old December 26th, 2007, 07:28 AM   #2
beejers
always building
beejers's Avatar
casting numbers. 61 usally came with 3:07.
beejers is offline   Reply With Quote
Old December 26th, 2007, 08:09 AM   #3
kickstand
circling the drain
kickstand's Avatar
What's the deal with the Dana 61?
With mileage and emissions concerns rising, at some point Dodge and / or Ford decided they wanted to be able to offer gears higher than the current highest ratio of 3.54 available in the D60. However, because of the design of the D60 the pinion head could not be made big enough to achieve a higher ratio. Hence, the birth of the Dana 61, which has a different casting that moves the pinion over 0.25"-0.437" (conflicting reports) - this allowed for a 3.07 axle ratio. The Dana 61 also uses 3.5" axle tubes. Other than that, it is very similar to the Dana 60. The Dana 61 was common in Dodge front ends and Ford van rears.
The difficulty with the Dana 61 is very limited gear and locker choices. However, you can use a combination of ring gear spacer and thick gear set to allow the use of differentials and gear sets intended for the Dana 60.
Slagburn reports: to run a 4.88 I had to go with series 3 carrier, series 1 being 4.10 and down, series 2 being 4.56 and up, then the series 3. PLUS a .160" spacer. That's the problem, nobody makes a full case locker for a 61, but it could be doable with a thick ring gearset AND a spacer.
Reider racing< Randy's R&P, and other sources make ring gear spacers for the Dana 61 .
http://www.reiderracing.com/ringspacer.htm
Old December 26th, 2007, 10:14 AM   #4
kickstand
circling the drain
kickstand's Avatar
crackerhead you dummy, you edited out the links that actually provided the answer for .
Old December 26th, 2007, 10:15 AM   #5
kickstand
circling the drain
kickstand's Avatar
http://www.pirate4x4.com/forum/showthread.php?t=546325
Old December 26th, 2007, 10:16 AM   #6
kickstand
circling the drain
kickstand's Avatar
http://www.pirate4x4.com/tech/billav...nt/index2.html
Old December 26th, 2007, 12:17 PM   #7
boggin-machine
thanks alot man
Old December 26th, 2007, 12:43 PM   #8
boggin-machine
from m reading the common dana 61s were rear axles only... but one guy said he had a front axle... is it only rears?
Old December 26th, 2007, 12:48 PM   #9
kickstand
circling the drain
kickstand's Avatar
No, dodge also used them in the front.
I think the two most common locations were ford van rears and dodge truck fronts (70-80's style dodges).
Old December 26th, 2007, 01:00 PM   #10
boggin-machine
ok thought so... so many people said they didnt excist that i didnt know...not actuall reading on them from dana so hard to tell... thanks again
Page generated in 0.27343 seconds with 53 queries
