Copper Fuel Lines? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 17th, 2006, 04:11 PM   #1
mschaffer66
mschaffer66's Avatar
Default Copper Fuel Lines?
Does anyone know of any reason why I wouldn't be able to run fuel through copper lines? Would it corrode? I don't think it will...but I just want to make sure before I do it.
Thanks
Old March 17th, 2006, 04:22 PM   #2
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Lots of old willies rigs have copper fuel lines. Lots of all the old vehicles had copper for that matter. I think they switched simply because of the cost of copper went up. I know the 62 CJ5 that I have in the shop right now is all copper.
Old March 17th, 2006, 04:30 PM   #3
mschaffer66
Thanks, thats what i wanted to hear :)
Old March 17th, 2006, 06:05 PM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I think alot had copper coated lines(steel under it) it used to be common because the cost of galvinizing was so much.
I have used Copper for lots of stuff the 3/16" is rated at 450lbs of pressure. the 1/4" is rated at 350lbs. I have ran the 1/4" up to 2000 psi and it didn't burst.
Yetti
Old March 17th, 2006, 06:19 PM   #5
$500 MJ
MJ conosuer
$500 MJ's Avatar
Send a message via MSN to $500 MJ
Propane, Nat Gas all use copper...
$500 MJ is offline   Reply With Quote
Old March 17th, 2006, 08:40 PM   #6
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Old March 17th, 2006, 09:08 PM   #7
mschaffer66
now with copper i will have to use flare fittings. Does anyone know how your standard say 3/8" fitting or tube converts to AN sizes?
Old March 22nd, 2006, 09:40 PM   #8
user name
keep your stick onthe ice
user name's Avatar
I just learned about this in class today. dont use it with electric pumps or alcohol. Electric pumps work harden the copper through the pulses and alchol corodes it. did here anything bad about it on carbs though. I ran it on my delta 88(injected) for a few months before it broke in half(car not lines) with no problems
Old March 23rd, 2006, 06:55 AM   #9
5.9zj
5.9zj's Avatar
Originally Posted by MuddyPaws
ya need to get the copper line a little close to the coil for some awesome fireworks
5.9zj is offline   Reply With Quote
Old March 23rd, 2006, 07:16 AM   #10
purplejeep
Oldbie
purplejeep's Avatar
When you ask about AN sizes I think aluminum. Don't put aluminum fittings on copper tube.
purplejeep is offline   Reply With Quote
Page generated in 0.46294 seconds with 53 queries
