i need a pittman are drag link - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 22nd, 2007, 02:38 PM   #1
19914x4blazer
ps4 tag chevytruckguy82
19914x4blazer's Avatar
Default i need a pittman are drag link
i need a pittman arm, drag link them for a yj Wrangler and i need a yoke for a front dana 30
19914x4blazer is offline   Reply With Quote
Old December 22nd, 2007, 04:28 PM   #2
mudd_jumper
mudd_jumper's Avatar
stock or drop?
Old December 22nd, 2007, 06:21 PM   #3
19914x4blazer
either one
Old December 22nd, 2007, 08:10 PM   #4
19914x4blazer
i would also like to find a pass side axel shaft for a d30 non vac dis
Old December 23rd, 2007, 04:51 PM   #5
19914x4blazer
no one has any of this
Old December 23rd, 2007, 06:23 PM   #6
xjrehab32
xjrehab32's Avatar
i have a shaft, but not the stub. its only the long one with the smaller u joint. 10 bucks
i also have a yoke for the front, its a dana 44 u bolt style. 20 bucks
i think i also have a drag link from an xj, but i will have to see what i have. i will get back to you if you are interested. send me a pm and we can work something out
xjrehab32 is offline   Reply With Quote
Old December 23rd, 2007, 06:40 PM   #7
19914x4blazer
is the shaft passenger side long inner from a non-vac disco axle i have the reg one i just do not want the vac disco i will take it ifs its the long one
will a Dana 44 yoke work on a Dana 30?
i will definitely take the drag link if you got it
Old December 23rd, 2007, 08:40 PM   #8
mudd_jumper
I have a stock pitman arm of a 95
Pm me since I forgot to check this post
Old December 23rd, 2007, 10:16 PM   #9
19914x4blazer
i might have a pitman arm still need drag link ,yoke and d30 passenger side long inner from a non-vac disco axel shaft
all parts for dana 30 front
Old December 24th, 2007, 10:16 AM   #10
two_much_talk
sit down shut up and ...
two_much_talk's Avatar
Talking
I have all that stuff.
1.) 4-6" drop arm
2.) complete passenger side axle shaft assemb with upgraded u-joint
3.) yoke
pm me if interested.
Old December 24th, 2007, 10:25 AM   #11
two_much_talk
Red face
I was in a hurry at work and a little st pid my stuffs for a TJ. the yoke and pitman arm might work .... but Im not sure...sorry
Old December 25th, 2007, 03:35 PM   #12
19914x4blazer
pm sent
Old December 28th, 2007, 10:24 AM   #13
greenmeanie
greenmeanie's Avatar
i have a drag link, but davisburg is over by the thumb isn't it? probably a bit far for you.
greenmeanie is offline   Reply With Quote
Page generated in 0.21097 seconds with 62 queries
