Dana 44 and r&p questions. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 21st, 2007, 04:54 PM   #1
Bronco Sally
Lets go wheelin
Send a message via MSN to Bronco Sally
Default Dana 44 and r&p questions.
First off for the easy one.. im goin 9" rear and d44 front, is it ok to run 4.90 in the rear and 4.88 up front? Its only locked when in 4x4.
also now the harder one..
Im goin fullwidth axles. My buddy has a d44 front. i was told i can use chevy flat top knuckles on it, but that will leave me with 6 lug outer. He tole me that i can use the chev knuckles with cj d30 outers and rotor and bearings set up and all.. anybody have info on this?? any help is appreciated. Thx Mike
so basically ford d44, chev knuckels and cj dane30 rotor, bearings, and this bearings shafts/flange thing. thx
Bronco Sally is offline   Reply With Quote
Old December 21st, 2007, 05:13 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
yes that is fine
use chevy small bearing spindles and ford hubs and rotors, you will use the chevy brake caliper and bracket. Also use the chevy stub shaft. I am running this exact setup.
Old December 21st, 2007, 05:59 PM   #3
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
If your going with new flat tops and highsteer, parts mike has a kit with Dedenbear 4 stud chevy flat top knuckles, with 5 bolt spindle pattern.
The kit with arms, balljoints, knuckles and hardware is like $749.
JcrOffroad
Zoom Zoom!
Old December 21st, 2007, 09:28 PM   #4
Bronco Sally
Lets go wheelin
om thx 99grand.. ill take a look into it a see exactly what i have to work with.. thx mike..
Old December 22nd, 2007, 08:53 PM   #5
Fraser
Fraser's Avatar
Originally Posted by 99grandtj View Post
yes that is fine
what year/ part # would the calipers and brackets be?
Old December 23rd, 2007, 01:49 PM   #6
Bronco Sally
Lets go wheelin
ok so now i just have to go pick up my axles and ill be good to go...
99grand that yes that is fine. was that about the gears?? Thx Mike
Old December 23rd, 2007, 04:05 PM   #7
Jeepaholic
Jeepaholic's Avatar
I am running 75 waggy (same as chevy) flat top knuckles, spindles, stubs shafts, caliper brackets, and calipers, and wheel bearings. Ford hubs, rotors, and wheel seals.
Pretty sure any year stub shafts, calipers and brackets work. But you have to use the small bearing chevy/fsj spindles, which IIRC are 70's era stuff.
Old December 23rd, 2007, 04:05 PM   #8
Jeepaholic
Jeepaholic's Avatar
Yes, they are close enough.
Old December 23rd, 2007, 09:36 PM   #9
Fraser
Fraser's Avatar
Ok, thanks. I already have the knuckles and the spindles, just wondering about everything else
Page generated in 0.23325 seconds with 50 queries
