cam ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 20th, 2007, 08:20 PM   #1
backdraft
AKA Patrick just because
backdraft's Avatar
Default cam ?
i have a 2005 5.7L ram daytona. can i put a 6.1L cam in it without any other chenges? if not what other changes are needed?
backdraft is offline   Reply With Quote
Old December 20th, 2007, 08:21 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
yes those cams are interchangeable.
Old December 25th, 2007, 08:54 AM   #3
backdraft
backdraft's Avatar
Do I Need To Do Any Thing With The Computer Or No
Old December 25th, 2007, 09:12 AM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
my suggestion. go with comp cams XFI cams. they work very well with stock computers and still give significant HP and TQ increases. if you decide to go to something more radical then yes you will need computer tuning to make your vehicle performs the best with a cam upgrade.
Old December 25th, 2007, 09:50 AM   #5
dline
dline's Avatar
the 6.1 cam is an high end cam, do you want a torque monster??? if so go with a comp 260 cam.
with any cam change i'd recommend at least 6.1l valve springs.
I have a comp 268 cam in my ram, with other things etc....
is your truck 2wd or 4wd??? quad cab or regular cab?
dline is offline   Reply With Quote
Old December 25th, 2007, 02:46 PM   #6
backdraft
backdraft's Avatar
quad cab 4wd not really looking for a torque monster but a little more then what i got for when i drag race the truck (sand not asphalt)
Old December 25th, 2007, 03:47 PM   #7
dline
dline's Avatar
comp 260 cam would be your friend
Old December 25th, 2007, 04:05 PM   #8
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
The XFI 260 netted 20 additional ft pounds of torque in lower rpm ranges with a peak of 31 additional hp. The XE 268 camshaft added 14 ft lbs of torque at low rpm and 47 additional peak horsepower. The amazing Comp Cams XFI 273 camshaft yielded it's most significant horsepower increases over 4500 rpm generating 61 more horsepower than the stock Hemi 5.7-liter engine.
copied from jegs
Old December 25th, 2007, 05:49 PM   #9
dline
dline's Avatar
yep hes gonna want some tq.
Old December 25th, 2007, 06:34 PM   #10
backdraft
backdraft's Avatar
thanks guys this will help out alot
Page generated in 0.30561 seconds with 53 queries
