Galaxy Dx93t Twin Turbine Amateur Radio 4 Sale in IN - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 16th, 2007, 11:00 PM   #1
Sgt Throttle
Default Galaxy Dx93t Twin Turbine Amateur Radio 4 Sale in IN
I have a GALAXY DX93T TWIN TURBINE AMATEUR RADIO. It has been converted to citizens band for sale.
Some specs...
* Dual Mini cooling fans on the rear increase the overall radio length by only one half inch
* New chassis incorporates a solid aluminum finned rear section as a heatsink
* Main circuit board upgraded to the same board as the DX 2517 base radio
* New "StarLite" faceplate is matte black with all lettering backlit in green and blue
* Retro-look red modulation lamp flickers like the old neon lamps of the Fifties and Sixties
* Exclusive "SuperSlider" circuit maximizes frequency control by switching the Fine clarifier between Receive/Transmit and Receive Only operation or completely out of the circuit with one slide switch. The Coarse clarifier operates on both receive and transmit unless the SuperSlider switch is off. When switched off, both clarifiers are out of the circuit.
* Switchable sixth digit provides five or six digit frequency display
* Red channel and frequency digits
* Front mic jack
* Heavy duty DC power cord
* A three-position power level switch takes the place of a variable output pot
* A 40dB attenuator switch takes the place of a receive gain pot
* A dim switch takes the place of a dimmer pot
* No On/Off switch for the frequency display
* No Roger Beep circuit
The DX 93T also has the following standard features found on other Galaxy radios: * Large, easy-to-read meter with 4 scales:
1. Calibrated power scale
2. SWR scale
* Echo with dual controls
* Talkback circuit with On/Off switch and volume control
* Meter glows red during transmit
* NB/ANL circuit with green LED indicator
I can send pics if anyone is interested. I am asking 375 OBO plus shipping.
Located in Indiana
Eric.
Sgt Throttle is offline   Reply With Quote
Old December 16th, 2007, 11:19 PM   #2
FlatFender
Tap Tap Splat
FlatFender's Avatar
its been converted to 11meter?
what kind of wattage does it put out?
Also, why are you asking so much? you can get them new all over the internet for $340? Does this one have any modifications that aren't listed?
Old December 18th, 2007, 08:15 PM   #3
FlatFender
Tap Tap Splat
FlatFender's Avatar
Old December 24th, 2007, 01:20 AM   #4
Sgt Throttle
It has been converted and peaked and tuned. On the low end it has been turned down to run a kicker and the high end has been turned up. I will have to talk to my friend that I am selling it for to get the exact numbers.
Old December 24th, 2007, 02:20 PM   #5
BAD
BAD's Avatar
any trades i have a 959 and i love it id like to find a nouther galaxy for my work velhicle
BAD is offline   Reply With Quote
Page generated in 0.16875 seconds with 38 queries
