remove axle shafts? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 13th, 2007, 11:53 AM   #1
66nick66
the not so beastly yj
66nick66's Avatar
Send a message via AIM to 66nick66 Send a message via Yahoo to 66nick66
Default remove axle shafts?
i have an 8.8 and i am trying to redo the brakes, but i also want to replace the parking brake on it because the shoes are terrible on it, so do i need to remove the axle shafts to fix the parking brake (im assuming it will be easier) and if i do then how do you remove the axle shafts? (be easy, never really worked on axles before)
thanks
nick
66nick66 is offline   Reply With Quote
Old December 13th, 2007, 11:57 AM   #2
kickstand
circling the drain
kickstand's Avatar
Assuming it is a c-clip 8.8 (they may all be but I dont know for certain).
Remove the diff cover, remove the center pin, push axle shaft "in" and c-clip will drop out, pull axle shaft "out", same with the other shaft. It's quite simple if you are able to do brakes and parking brake components, you should have no problem removing the shafts on an ability level.
Old December 13th, 2007, 12:11 PM   #3
66nick66
66nick66's Avatar
ill go try that right now
Old December 13th, 2007, 12:11 PM   #4
natureboynate47
natureboynate47's Avatar
you don't have to take the shafts out to replace the parking brake shoes, but if you need to change the gear lube it would be a good way to kill two birds and it would be easier with the shafts out
X2 what he said on getting the shafts out
natureboynate47 is offline   Reply With Quote
Old December 13th, 2007, 12:17 PM   #5
66nick66
66nick66's Avatar
thanks for the input natureboy, but i already have the shafts out haha, thanks up_roktoy
Old December 13th, 2007, 01:55 PM   #6
kickstand
circling the drain
kickstand's Avatar
Not tough at all once you get in there.
Old December 13th, 2007, 03:08 PM   #7
66nick66
66nick66's Avatar
no not at all, thanks again
Old December 14th, 2007, 07:17 AM   #8
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
You got them out in 6 minutes. thats quick!!
RIP FULLSIZE4LIFE
Old December 14th, 2007, 08:47 AM   #9
66nick66
66nick66's Avatar
haha i know, for once everything went right on something that i was working on
Page generated in 0.22862 seconds with 50 queries
