Welded threaded inserts vs threading the tube - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 10th, 2007, 04:09 PM   #1
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Default Welded threaded inserts vs threading the tube
Welded threaded insert or threading the tube. What one would be better to do? Going to be for the steering on my XJ. I'm leaning more towards the inserts because I won't need to buy the taps then. Something along these lines Not a bad price either, just the tubing isn't long enogh for what I need.
Old December 10th, 2007, 04:43 PM   #2
Bones
Bones's Avatar
I did weld inserts for simplicity.
if you're going to try to hand tap 7/8 threads invite me over so I can watch (I assume you don't have a lathe)
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old December 10th, 2007, 04:49 PM   #3
Kaiser42
Kaiser42's Avatar
I would do solid 7076 alum. and tap it
Unimogs,LS-1,42's and a few other mod's
Kaiser42 is offline   Reply With Quote
Old December 10th, 2007, 05:03 PM   #4
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Well I do, Also have a 300 amp TIG welder, so either way is no problem. :sonicjay
Old December 10th, 2007, 08:49 PM   #5
Bones
Bones's Avatar
then buy the taps... that way you're ahead of the game for when you build a front and rear 4 link.
If you can afford buying AL, do it. I couldn't, so I went with DOM...
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old December 10th, 2007, 08:52 PM   #6
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
whatever you do, make sure you jam-nut it and make sure they are tight.
I used inserts on my current tie rod because it was easier. The last one I threaded, it was not bad, but we borrowed a 2-foot t-handle.
Old December 11th, 2007, 12:01 AM   #7
sodapop
Support the Sport!
sodapop's Avatar
I did weld in bungs for ease of assembly. Plus if a bung's threads ever get's messed up, I can grind it off and put a new one on saving my tube.
Old December 11th, 2007, 12:59 AM   #8
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
i have on several occasions.. its not that bad.. its not that good.. but its definately not that bad either .. prolly do full tierod/draglink in about 15-20min :D ..
nixxerRsixxer is offline   Reply With Quote
Old December 11th, 2007, 09:09 PM   #9
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Well I'm doing the bung's $140 ish for two taps in not worth it to me. It's for the cross over steering on my WJ knuckles.
Old December 12th, 2007, 09:22 PM   #10
bender
Your daily fullsize fix.
bender's Avatar
Send a message via AIM to bender Send a message via MSN to bender Send a message via Yahoo to bender
yup, same here for my traction bars we made.. found them for pretty cheap on ebay.
bender is offline   Reply With Quote
Old December 12th, 2007, 11:17 PM   #11
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
I like direct tapping because you get tons more thread engagement. We used to do it by hand back in the day, it wasn't fun... but it wasn't impossible. I made a jig for the mill to do it now. Makes a much straighter tap, and that means a better jam nut engagement.
If you measure your lengths (center of hole to center of hole) I can send out rods tapped and match that CompleteOffRoad.com price with TRE's and jam nuts.
We have some other TRE parts numbers for the tie rod that we use in cross over setups get rid of the long ES2233L and they look a ton nicer + are stronger. If one is going to bend, it's going to be that ES2233L.
Let me know, I would actually like to get the numbers down so we can offer a WJ conversion steering setup on the site
JcrOffroad
Zoom Zoom!
Old December 12th, 2007, 11:23 PM   #12
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Heims with 7/8 thread are 14tpi.
GM TRE's, some spark plugs, and this, are pretty much the only place you find 7/8 - 18.
JcrOffroad
Zoom Zoom!
Old December 13th, 2007, 03:56 PM   #13
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Will do going to be a little bit before I get it done. Kind of off topic but do you think I'll have any problems with doing the tie rod OTK?
Old December 13th, 2007, 04:17 PM   #14
Bones
Bones's Avatar
shit, I keep forgetting people use TREs lol
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old December 13th, 2007, 10:34 PM   #15
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
You know back when i did mine on the YJ there was a reason i didn't go OTK for the tie rod. It was either because it would hit my springs, or because I couldn't get the reamer in from the top with the upper arm in the way.
I haven't had my hands on a WJ knuckle in a while though, so I can't be sure.
If it works ok, you will need to trim your coil buckets back to the coils, cut off your steering stabilizer mount, and relocate your sway bar mounts. I could throw a couple slight bends in the end of the tie rod for clearance, but I have never ran that before, so I don't know about it's strength.
JcrOffroad
Zoom Zoom!
Old December 14th, 2007, 07:05 PM   #16
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
All ready planned on moving the sway bar links, relocating the track bar to the top of the axle with a JKS mount, and cutting the buckets back.
Old December 14th, 2007, 07:14 PM   #17
FlamesFearMe
Custom User Title
FlamesFearMe's Avatar
If your steering looked like this I would "tap" her in the "bung".
FlamesFearMe is offline   Reply With Quote
Old December 29th, 2007, 11:08 PM   #18
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
i had my neighbore make me slugs for my DOM steering. Than i heated up the DOM and put the slugs in the freezer, bashed them in there, had holes 3 holes drilled in the DOM , filled those with weld. So i have a pressed tight fight that is spot welded
Old December 30th, 2007, 09:37 AM   #19
lgottler
lgottler's Avatar
As for better thread engagement with tapping, I disagree. If the bungs are threaded properly with the proper &#37; of thread engagement, they should be equal to threading the tube. Also, the rule of thumb for minimum thread depth for max. bolt pull out strength is 1.5x the diameter of the fastener. So, a 3/4" tie rod end would need 1 1/8" of thread engagement and I think most threaded bungs are at least 2" long.
I'm talking push/pull, no side loads....in steel. I use 2x dia. for alum at work, but thats just my guess for alum.
Lucas
lgottler is offline   Reply With Quote
Old December 30th, 2007, 09:42 AM   #20
Ebs
I'm no engineer, but press fit steering linkages sounds pretty scary.
Page generated in 0.50899 seconds with 83 queries
