dana 44. 5 lug to 8 lug? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 10th, 2007, 12:06 PM   #1
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
Default dana 44. 5 lug to 8 lug?
alright i have a dana 44 in the front of my 84 dodge half ton. i would like to find a dana 60 eventually, but in the event i can't find one or it's way to expensive. how hard is it to convert my 5 lug to an 8 lug. is it as simple as changing the hubs and brakes? or do i need new knuckles as well. i already have flat top knuckles in the truck so i can do my high steer/crossover set up and would like to keep them. i already have a FF dana 60 rear that will be going in the truck after i lift it. i don't wanna have to run 2 diffrent sets of wheels when i get my truck done.
Old December 10th, 2007, 02:40 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
best to get the spindle/hub/rotor/caliper bracket/caliper ans swap it, but yes it is bolt on stuff
Old December 10th, 2007, 03:34 PM   #3
fsumotorhead
N8KVB
fsumotorhead's Avatar
X2, i think you need the 6 bolt chevy style spindles. I believe Ford had a 5 bolt spindle.
Old December 10th, 2007, 04:37 PM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
are parts from a 10 bolt chevy interchangeable with a dodge dana 44? i can possibly get all the outer parts from a 8 lug chevy 10 bolt. what about axle shafts? are they diffrent between 1/2 and 3/4 ton?
Old December 10th, 2007, 05:31 PM   #5
Jeepaholic
Jeepaholic's Avatar
10 bolt stuff will work, shafts are the same between 1/2 and 3/4 ton
Old December 10th, 2007, 06:04 PM   #6
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
ok cool i guess i'll work on collecting the parts i need then thanks for the help guys.
Page generated in 0.16883 seconds with 41 queries
