Wanted: TJ motor mounts 4.0 Throttle body etc. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 9th, 2007, 05:03 PM   #1
KTM Mike
Default Wanted: TJ motor mounts 4.0 Throttle body etc.
I am swapping the 2.5 in my 97 TJ for a 4.0. Perhaps you recently swapped a V-8 in place of your 4.0 and have some of the parts I need! I already found the Harness and ECM - still looking for the motor mounts - the part that welds onto the frame side from 97 to 2005? TJ 4.0. Also still looking for 4.0 Throttle Body with sensors etc. for ODBII
Odds and ends - TJ fan shroud for example...
Will buy outright, or trade for my XJ stuff
Best way to contact me is by emailing me at KTM_Mike@hughes.net.
Thanks
Mike
KTM Mike is offline
Old December 12th, 2007, 08:17 AM   #2
KTM Mike
Bump - still looking for parts needed. Trade or cash outright OK by me.
KTM Mike is offline
Old December 15th, 2007, 09:43 AM   #3
KTM Mike
Still looking....
KTM Mike is offline
Old December 19th, 2007, 05:47 PM   #4
KTM Mike
Still looking...seems I can find pre 97, or post 98...nothing 97 or 98!
KTM Mike is offline
Old December 26th, 2007, 09:11 PM   #5
KTM Mike
Update...got the wiring harness and ECM... still need mounts, throttle body and odds and ends...
KTM Mike is offline
Old December 27th, 2007, 09:45 PM   #6
LuckyCharm4x4
LuckyCharm4x4's Avatar
Send a message via AIM to LuckyCharm4x4 Send a message via Skype™ to LuckyCharm4x4
will these get you started? (it's towards the bottom of the first post)
http://www.greatlakes4x4.com/showthread.php?t=68969
~Bry
LuckyCharm4x4 is offline
Old December 27th, 2007, 09:54 PM   #7
KTM Mike
Bry - close...but not quite. the mounts you show there are the part that bolts to the engine block, then one of the part that goes between the engine block mount and frame mount. What I am looking for is the part that is welded onto the frame. I might be interested in the throttle cable, and a few other items though once I get a bit further into this swap. Thanks.
Mike
KTM Mike is offline
Old December 28th, 2007, 09:19 AM   #8
rubicon 1
Default frame brackets tj
I am getting 6cly. brackets to weld on a 4 cly.frame like you are.so far I got the top part of the bracket from the dealer part numbers are #52058864 and #52058865,price was $28.50 and $34.75.I have ordered the botton part of one side to see if it is the right part or not.will let you know if it the right part or not when it comes in.if you know any one who is a chry.person,you could get the parts cheaper.thanks.jeep man of westland.
rubicon 1 is offline
Old December 28th, 2007, 10:19 AM   #9
KTM Mike
Rubicon - Interesting timing! Based on the time of your post, I was on the phone with a Jeep dealer at the same time asking about mounts! I am confused with the top part and bottom part though? Is the top part the part that bolts on top of the frame mount, big motor mount bolt goes through it connecting it to the engine bracket (part that bolts to block).?
Dealer parts guy I spoke to said he could get (what I assume to be bottom part) part that welds to frame for $30 on one side, and $37 other side. He did mention something about a "Reinforcing bracket" that was specified only for the 2.5 liter, for about $20 each side - no clue what that is about.
Anyhow - LMK what you find out! Based on how relatively in expensive new mounts are, I may go that route (unless I can get some used ones for REALLY cheap!)
Mike
KTM Mike is offline
Old December 28th, 2007, 05:26 PM   #10
rubicon 1
Default engine brackets
mike,the 2 parts numbers that I gave you are the left and right top part that is welded to the frame .there is a reinforcing bracket under these brackets.these are the brackets that I working on .I ordered one to see if that is the right reinforcing bracket.there is a metal bracket with a rubber
bushing in the center that bolts to the top of the 2 part numbers that I gave you,I beleive there's a bolt goes through that bracket.I will let you know more when the part I ordered comes in.the dealer's part pictures don't show much.thanks,jack
Old December 31st, 2007, 08:18 AM   #11
KTM Mike
Jack
Thanks for the follow up. Please do let me know what you find out. I think I am going to order the parts you had #s for today - at least I can get those in hand. When I do, I am going to pick the brain of the parts guy a bit more on those "reinforcing brackets" - he was adamant those were shown as 2.5 only. Yet, when I removed my 2.5 brackets - I dont really see anything that would seem to be a separate "reinforcing bracket". I wonder if it is some sort of later model upgrade - or they are indeed for the 4.0? My TJ is a 97.
KTM Mike is offline
Old December 31st, 2007, 08:32 AM   #12
Sol Goode
Obama Nation!
Sol Goode's Avatar
send a pm to quagmire,
I think he has all this stuff
Sol Goode is offline
Old January 7th, 2008, 07:20 PM   #13
rubicon 1
Default tj 6cly.brackets
I ordered the one reinforcing bracket from the dealer and it will work out ok.there is a right and left reinforcing bracket.the part numbers are 52058845 and 52058911.you will have to look at a 6cly.frame setup to see how the brackets are welded on and the location where on the frame,as the brackets are farer up the the front of the frame.I have a frame to look at if you need to check that out.it's in westland.mi hope this info. helps you out.jack
Old January 7th, 2008, 07:40 PM   #14
ouchman
ouchman's Avatar
Send a message via Yahoo to ouchman Send a message via Skype™ to ouchman
i have an intake and throttle body, if your still looking
support the sport- www.GLFWDA.org - member
Dear Travelers,
You won't see London and you won't see France, until we see your underpants!
Sincerely, TSA Officers
ouchman is offline
Old January 7th, 2008, 09:19 PM   #15
KTM Mike
Jack - thanks. I ended up ordering the basic brackets (not the "reinforcing bracket") got them Friday - one quick look told me no way would that be adequate without the reinforcing brackets. I dont understand why they are sold separately even...does not make sense to me! Anyhow - thanks for the part #s - my local dealer did not seem so sure what I was asking for! As to location - I think I found a good source online, plus I plan to "test fit" my engine, with brackets bolted to it...line up with frame and tack them in place.
Ouchman - I already found a throttle body. I might be interested in the intake though. Send me more details.
Mike
KTM Mike is offline
Page generated in 0.44657 seconds with 68 queries
