"Bullet Proof Diff Covers" $110 TYD - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old December 9th, 2007, 12:47 PM   #1
greatlakeoffroad
Steel Guru
Default "Bullet Proof Diff Covers" $110 TYD
Bullet Proof you ask? JP magazine said so not us........
First I want to say a couple of things. We weld our covers, we are the only ones who will weld our covers. My main reason is this, I take pride in our product and the quality and look of it. I pay extremely well for the best welders in the country to do these units and amazingly they are built here locally. I do not charge extra for this as I believe you should have the best available for your hard earned money. For those of you who know what a quality weld looks like you know who and what I am talking about. Do not let someone scare you into thinking welding is a weak point either and if you believe this do not walk into any steel structured buildings ever again as every joint has at least one weld on it. Difference is in the engineering thus why use 3/8" when it is apparent 1/4 will not break. If you wheel you do not want a heavy rig it adds up and may make obstacles unobtainable that a lighter vehicle would have ran easily. We know this because we actually wheel a rig for recreation / competitions instead of say canoeing. Get my drift. Comp Tested, Customer Approved Built right hear in Steel Central
Well, in the 6+ years we have been producing these there have been alot of changes and updates to our line. I thought that we should try and cover all of our options and updates here for you since we are new to this board.
So here are our specs................ all for $100 per cover
- Bolt ring 1/2" thick (we engineer strength where it is needed )
- 1 pc machined fill plug, placed for added oil capacity (Sterling and 8.8 can be added upon request)
- 1/4" thick one piece cnc formed cover (why not thicker? read the warranty)
Only at Glo x-tra cost options......................
- Counterbored mount holes (yes all of them, for a clean quality look)
- Integrated drain (ever cross deep water? Drain it out replace fluid and go)
- 1/2" mid plating severe abuse, makes a nice hydro steer mounting point
- Upper Truss Tab (nice for hooking into your homemade truss)
- And everything in between
Models available
Dana 80
Dana 70
Dana 60
Dana 44
14 bolt 10.5" R&P
14 bolt 11.5 R&P (to be released week of 8-25-06)
Ford Sterling
Ford 8.8
Warranty ( No B.S. Fine Print )
You break it under use we replace it and add you to the hall of fame as it has never been done in the last 6 years. Our design has been engineered for strength. We weld these the proper way utilizing machined fixtures
Running Rockwells? We have a cover for that too just ask us for a quote. Thanks Shawn
greatlakeoffroad is offline   Reply With Quote
Old December 9th, 2007, 12:53 PM   #2
greatlakeoffroad
Steel Guru
14 Bolt Cover w/ tread plate option only here at GLO
Old December 9th, 2007, 12:55 PM   #3
greatlakeoffroad
Steel Guru
Default Standard 14 Bolt cover example
Old December 11th, 2007, 10:05 AM   #4
greatlakeoffroad
Steel Guru
Thanks for the orders guys, Shawn
www.greatlakeoffroad.com
Shawn4x4@greatlakeoffroad.com
For Quick Order Processing Call Tonya 260-387-1428
Old December 13th, 2007, 05:22 PM   #5
greatlakeoffroad
Steel Guru
Understand we are not selling gimics, but we will sell you a quality product.
#1 - The truth is we have been building these for over 6 years w/ not one single warranty issue. Realize 1/4" mtl is more than enough that's why its called engineering. The bolt ring is 1/2 inch where it is needed. We do not start w/ 3/8" plate and then mill it thinner. Since I sponsor everyone from XXRA competitors to all the other big name circuits I think if there was an issue we would have found it in the several thousand covers we have produced.
#2 - Understand, I am the laser source and buy the mtl by the truckload (45,000lbs) at a time. I can buy A50 plate for the same price as the A36, yield strength means nothing in this application. Look at the design, again it goes back to engineering.
#3 - If you don't know how much fluid to put in a diff pay someone to do it for you. We take care of the guys utilizing rotated housings also. We put drains where they work most effectively and can take any abuse. Understand it is protected by your housing and surrounded by half inch mtl. Again not a single issue.
#4 - Sealing is not an issue and never has been, yes we fixture our parts when welding just because someone else does not know how to build a fixture does not mean we do not. Again, I have made my living building steel components for everybody from GM to Honda so if I can pass there requirements I can pass yours.
#5 - You get what you pay for, this includes machining and also welding. You will not find a finer product out there than our cover. This is the reason we do not offer kits, if you have seen our covers we welded them and the quality is top notch like you would expect for paying a bill for. If there are any questions buy both my cover and someone elses. Sit them side by side and decide for yourself.
#6 - We ship world wide and in the US for no additional money.
#7 - We have the best pricing available, if you would like to become a vendor or do a group buy let me know we can take care of you w/ exceptional pricing. Remember you are buying direct from the source not a middle man. I buy steel by the truck load (45,000lbs at a time) not by the pallet.
#8 - We currently offer nine different covers w/ more options than anyone else. I can honestly say this cover is our design and I built it the way I an avid wheeler wanted it to be, light and strong. No reverse engineering here. More models due out shortly. I will not promise when and not deliver again and again.
#9 - No BS no fine print warranty. You mangae to break it we replace it. Period. However I wish all of you good luck trying.
All Standard housing covers start at $110 shipped TYD lower 48. Not some and then say "well its bigger it costs more but hey we have a discount we give to everyone" so it really is not that much more.
Lastly,
Our covers have won magazine reviews (JP Magazine), been seen on TV shows such as Xtreme 4x4 and run by some of the best builders and racers in this country and around the world. We are proud to say we built each and every one of them in house from start to finish no one else can say this. I will not blame someone else for any defects in my product. Our products get you the best bang for your buck and will not leave you stranded in some remote area 10 hrs from home. Only after spending $500 worth of tow rig fuel to get you there and be broke down. Realize I know this feeling and it stinks, I will not do this too you. If you want the best there is to offer for your rig we have it, right here close to your home where we all wheel. Thanks Shawn
Old December 26th, 2007, 05:33 AM   #6
greatlakeoffroad
Steel Guru
Ttt
Old September 26th, 2008, 12:39 AM   #7
dwain morrison
Default ???How to order???
Need a 14 bolt cover, as heavy duty as possible, so how do I order from you?
Dwain Morrison
dwainmorrison@sbcglobal.net
dwain morrison is offline   Reply With Quote
Old September 26th, 2008, 12:43 AM   #8
dwain morrison
Well, all of a sudden I've found your info, sorry about that
Thread Tools
Page generated in 0.37495 seconds with 48 queries
