Im stuck.... Shafts? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 8th, 2007, 04:06 PM   #1
Theidt88
Boggers boy
Theidt88's Avatar
Send a message via AIM to Theidt88
Default Im stuck.... Shafts?
So i got some 27 spline Zj shafts for my 93 wrangler, these i guess arw a littttle but longer not much but will fit. Which they did, But after i swaper the driver side in and took off in 4 wheel drive something inside was binding up? 2 wheel free spinning they are perfectly fine, what could this be. My ring and pinion fucked or the shaft isnt working properly. I only got to put the driver side in tho because of the vacum disconnect, would this cause it to not work seeing the passenger side is slightly different. im clueless and cant figure it out, any help would be great thank you...
Theidt88 is offline   Reply With Quote
Old December 8th, 2007, 04:10 PM   #2
xjmichigan
xjmichigan's Avatar
Did you take the cover off and look at the r+p after your incident?
Old December 8th, 2007, 04:55 PM   #3
Theidt88
Boggers boy
Theidt88's Avatar
Im going out right now to check that out... :-(, i really dont want to which sucks...
Old December 8th, 2007, 05:23 PM   #4
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
I have had to grind a 1/4" off the ends before. It is binding on the cross shaft. You can fell it bind by hand. Jack the vehicle up and cycle the steering side to side by hand at the wheel. You will be able to see what it is doing as well. It won't take long to wipe out the inner tube seal on that side as well.
Old December 8th, 2007, 07:45 PM   #5
Theidt88
Boggers boy
Theidt88's Avatar
K found out what the binding was, detroyed the ring gear. Missing like 15 teeth which is rediculous seeing i just got it all professionally done as of over a month ago. Brand new in the box from yukon so im pretty pissed. Thanks, anyone got a 44 with 4:88's ready to sell.
Page generated in 0.18820 seconds with 38 queries
