help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 8th, 2007, 09:52 AM   #1
vwBOY
it's how i roll
vwBOY's Avatar
Default help
i have a 1994 f-150 ext. cab short bed with a 302 and an e40d trans and it is only getting 10 miles to the gallon i have just done a tune up new plugs wires cap and rotor and it still gets ten miles to the gallon any help would be appreciated on this it is killing me
vwBOY is offline   Reply With Quote
Old December 8th, 2007, 10:23 AM   #2
broncobuddha
Starting over
broncobuddha's Avatar
Send a message via AIM to broncobuddha
if you have a haynes manual do the check for codes procedure, sounds like 02 sensor or plugged cats, but the first step is pull those codes from the computer, you can also check fordfuelinjection.com lots of good info on how to diagnose this kind of problem
broncobuddha is offline   Reply With Quote
Old December 8th, 2007, 12:17 PM   #3
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
City or highway? How friendly with the throttle are you? whats your gear and tire size?
Old December 8th, 2007, 12:24 PM   #4
vwBOY
it's how i roll
vwBOY's Avatar
thing is that it has new cats and o2 sensor could a bad tranny have anything to do with it
Old December 8th, 2007, 12:24 PM   #5
vwBOY
it's how i roll
vwBOY's Avatar
city and highway very easy on the throttle no fast take offs and i do 65 on the freeway
Old December 8th, 2007, 12:39 PM   #6
Captain Ledd
Ranger Addiction?
Hmm.. I'd think it'd be a little better than that then... no idea.
Old December 8th, 2007, 01:07 PM   #7
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
air filter?
@clarkstoncracker
Old December 8th, 2007, 01:24 PM   #8
broncobuddha
Starting over
its possible, do you feel your tourqe converter lock up? if it isnt it could cut mileage, i would check that and those codes
Old December 9th, 2007, 09:20 AM   #9
vwBOY
it's how i roll
vwBOY's Avatar
the truck dosent like to go into overdrive
Old December 10th, 2007, 10:03 AM   #10
fsumotorhead
N8KVB
fsumotorhead's Avatar
10-12mpg is normal for those trucks, they are horrible on gas, my '93 F-250 only got 4-6mpg
Old December 18th, 2007, 01:12 PM   #11
Westside Willy
Westside Willy's Avatar
I am going by memory here but seems like there was an issue with running the #7 and 8 spark plug wires next to each other caused a low power/ poor fuel economy problem. try routing them as far away from each other as you can and see if that changes anything. this may have been on the earlier 302 86-90 era truck engines with the 302 firing order vs. yours should use the 351w / 302 HO firing order.
Westside Willy is offline   Reply With Quote
Page generated in 0.25862 seconds with 56 queries
