Should I 4x4 it? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 7th, 2007, 12:31 PM   #1
Chiefwoohaw
Pokerob is my B*tch!
Chiefwoohaw's Avatar
Default Should I 4x4 it?
I started this new thread because it's a diffent question.
I have a 4x4 ZF trans in my truck. Should I buy the BW1356 t-case and put it in my 2wd truck in anticipation of 4x4ing it later or just buy the ZF driveline brake.
This truck will only be a tow rig but I thought having 4x4 would be cool. I do live in a hilly part of the US.
Later I would buy ford D44 for up front and then well lots of other stuff.
Right now I would just have to buy the t-case and get a new rear drive shaft. I have to buy a new rear DS right now anyways because the one on it is a complete hack job.
Old December 7th, 2007, 12:40 PM   #2
03hemisilver
Pres MI Dodgetruckworld
03hemisilver's Avatar
yes, and I have all the parts you need out of my 90 Bronco full-size :tonka:
80 CJ frame, YJ body, 304 cid, 4" lift, 35"s, 4.10's, locked, 8K winch, garage queen
2012 F150 4x4 Lariat Supercrew Ecoboost
03hemisilver is offline   Reply With Quote
Old December 7th, 2007, 12:48 PM   #3
Chiefwoohaw
interesting
Old December 7th, 2007, 01:56 PM   #4
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I think a 44 will be too small for your 250; most people put a 60 in; you might even be able to find a TTB50 for cheap...
@clarkstoncracker
Old December 7th, 2007, 02:21 PM   #5
Chiefwoohaw
Do you say this because of the weight of the truck or the width of the axles? I forgot that I'll need something up front that is an 8 lug.
Old December 7th, 2007, 03:39 PM   #6
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I think the width and the weight - the older f250s that had 44's never had 1500# of motor sitting over them.
@clarkstoncracker
Old December 7th, 2007, 03:48 PM   #7
bigjay
The Man Myth And Legend
bigjay's Avatar
Location: i can piss on the allegan and barry county line at the same time.. ...
ohio has hills???
bigjay is offline   Reply With Quote
Old December 7th, 2007, 04:05 PM   #8
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Originally Posted by bigjay View Post
ohio has hills???
Ever been to southern Ohio? There's quite a few down there on the Appalachian Plateau.
@clarkstoncracker
Old December 7th, 2007, 04:53 PM   #9
Chiefwoohaw
that kinda looks like my backyard
So I was over on powerstoke.org and they said that the only manual behind the 7.3L was the ZF5 in and then ZF6 in the newer years. And the only T-case was the BW 1356 so . . . I can search 133" WB 4x4 7.3L with Manual Trans and get the correct Drive Shaft!!!
And then look for a TTB60 in the spring! double woot
Old December 7th, 2007, 05:12 PM   #10
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I thought the big TTB was a 50 and the solid axle 60 was used in the 1-tons(?)
@clarkstoncracker
Old December 7th, 2007, 05:57 PM   #11
Chiefwoohaw
Beats me. . . I thought you miss typed when you put 50 in there instead of 60
yeah, I need to do much more research!
Old December 7th, 2007, 06:12 PM   #12
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
The 3/4 ton TTB is D50. Look at the "Dana axle" sticky in the axle tech section.
@clarkstoncracker
Old December 7th, 2007, 06:32 PM   #13
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Don\\\\\\\\\\'t look too easy...
@clarkstoncracker
Old December 7th, 2007, 07:22 PM   #14
Chiefwoohaw
I'll look at that site you just posted but from what I've been reading it's a direct bolt in.
Thanks again for all the sugguestions and advice scoots!!
Old December 8th, 2007, 07:28 AM   #15
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Not quite a direct bolt-in, there's some cutting of the frame involved, i.e. front shackle mounts and the shock "towers".
@clarkstoncracker
Old December 8th, 2007, 01:06 PM   #16
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
I was out crawling around under the front of my truck, an I think a TTB50 would be a bolt-in ordeal.
I doubt I"ll ever do it to mine - too much work for a truck I only plan keeping until 250k (three more years, hopefully)
@clarkstoncracker
Old December 10th, 2007, 09:57 AM   #17
fsumotorhead
N8KVB
fsumotorhead's Avatar
I have a TTB 50 in my back yard with a 4:10, also have a 1356 T case. If you bought a shackle reverse kit, there is no need to mod the frame. You would just need the rear spring mount, which i have. Also have a 6" lift.
Old December 10th, 2007, 10:00 AM   #18
fsumotorhead
N8KVB
Old December 10th, 2007, 10:51 AM   #19
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Dang - I thought they used radius arms on the 50.
@clarkstoncracker
Old December 10th, 2007, 01:15 PM   #20
Chiefwoohaw
So did I. I had no idea it came with leafs
FSU motorhead if it's still around in the spring want to sell it as a package deal and help me install it
Page generated in 0.49830 seconds with 83 queries
