'86 F-150 stuff - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 7th, 2007, 09:43 AM   #1
Bronco351
Powered by Ford
Bronco351's Avatar
Send a message via Yahoo to Bronco351
Default '86 F-150 stuff
got an '86 f-150 lariat, was my grandpa's, but my grandma said i could have anything i wanted off it. thinking about taking the 302 out (40k approx) and swapping it into my B2. first off what T-case and trans did the '86s come stock with and would i have to swap those into my B2 along with the 302?
thanks
Bronco351 is offline   Reply With Quote
Old December 7th, 2007, 09:47 AM   #2
broncobuddha
Starting over
broncobuddha's Avatar
Send a message via AIM to broncobuddha
3 speed auto would be a c6, 4 speed a aod, transfer case bw 1356 most likely, if its a stick shift it could be a few differrent things
broncobuddha is offline   Reply With Quote
Old December 7th, 2007, 09:50 AM   #3
Bronco351
Powered by Ford
Bronco351's Avatar
its an auto, pretty sure its 4-speed, cant really tell though, it has a cracked manifold so its deafeningly loud, never got it over 35
Old December 10th, 2007, 10:23 AM   #4
mooseracing
Stuck like a MoFo
mooseracing's Avatar
Send a message via AIM to mooseracing
My 85 lariat has the NP208 tcase behind it. For the NP the tag is on the back of the case, and round.
You would have to swap the tranny for sure, or another Ford SB housing tranny into your B2 if using that motor since the BP is different. I'm not sure what t-cases besides the 1/2ton - one ton adapters are the same.
mooseracing is offline   Reply With Quote
Old December 10th, 2007, 03:28 PM   #5
busyfixin
Balls Deep
busyfixin's Avatar
there are alot of 1345's around too. that seems to be what most 86-90ish's i come across have. not all, but most.
Old December 11th, 2007, 02:58 PM   #6
Bronco351
Powered by Ford
Bronco351's Avatar
I think the ID tags might be rusted off, is there any other way to tell what each one is?
Old December 11th, 2007, 03:10 PM   #7
mooseracing
Stuck like a MoFo
I haven't seen a NP with the tag rusted off. Newer one that is......Either way google image search is your friend.
Old December 11th, 2007, 03:23 PM   #8
88mudder
In the band!
take some pics of the trans and t-case and we can try to identify
Old December 12th, 2007, 09:00 AM   #9
Bronco351
Powered by Ford
Bronco351's Avatar
sounds good, probably wont get pics till around new years, truck is 200 miles north of me.
Old December 19th, 2007, 11:06 AM   #10
frdtrckmnrich
FORD The Best Never Rest
frdtrckmnrich's Avatar
You will have to dump the t-case anyway.They won't fit inside the frame rails on a b2. However a np205 will and if you have the 3-speed it would prettymuch bolt up. I think it might even bolt up to the 4 speed but i am not completely sure.
Old December 21st, 2007, 12:15 PM   #11
dirtybronco287
dirtybronco287's Avatar
Where is the truck? I'm headed north this weekend and if it's near where I'm going or on the way I'm sure I could stop and look. I've had enough of these trucks to know.
By the way there's a NP208 in my B2 in the avatar.
It had a 302, c6, NP208, D44 ttb, and a 8.8.
dirtybronco287 is offline   Reply With Quote
Page generated in 0.28204 seconds with 56 queries
