Don't freak if your 5.9L A/C compressor clutch isn't kicking in this winter. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 6th, 2007, 11:40 PM   #1
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Default Don't freak if your 5.9L A/C compressor clutch isn't kicking in this winter.
Apparently there is an ambient temp sensor for the system that will only cycle the clutch if it is warmer than 32 degrees out. I never knew that. Every other vehicle I've owned or worked on it would cycle no matter what.
I thought mine was broke, didn't want to screw with it, so the dealer was able to divulge that information to me for $40 diag. fee.
I couldn't find any info online about it, but I'm assuming it would be similar with other Chrysler products.
Old December 7th, 2007, 07:36 PM   #2
PavementPounder
PavementPounder's Avatar
So they decided you don't need dry air when its below freezing?
Old December 7th, 2007, 07:54 PM   #3
GreaseMonkey
Pew pew!
Apparently. I don't quite know what purpose it serves, but when air gets down to 20 some degrees, it isn't going to be holding much humidity anyways. Why go the extra step with the system is beyond me.
Old December 7th, 2007, 08:10 PM   #4
PavementPounder
Yes, but that's outside the truck. The HVAC blows air on the inside of the truck which is where your breath is. I agree, you bought a stupid truck. :tonka:
Old December 8th, 2007, 04:55 PM   #5
GreaseMonkey
Pew pew!
Kettle...pot...black?
Old December 8th, 2007, 05:01 PM   #6
PavementPounder
I don't have a 360.
But I'm not going outside and testing it.
Old December 8th, 2007, 05:03 PM   #7
bigjay
The Man Myth And Legend
bigjay's Avatar
Location: i can piss on the allegan and barry county line at the same time.. ...
my 318 does the same thing
bigjay is offline   Reply With Quote
Old December 8th, 2007, 08:58 PM   #8
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
the reason they don't want the A/c compressor turning on when the outside temp is below 32 degrees is because the evaporator will freeze and clog with ice in which the result is no air flow.
Old December 8th, 2007, 11:16 PM   #9
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
x2
and we did it at Ford because the system could potentially burst a line in cold weather.
@clarkstoncracker
Old December 9th, 2007, 12:02 AM   #10
PavementPounder
I'm thinking that would have nothing to do with air flow in the HVAC system at all. Ever.
Old December 9th, 2007, 07:39 AM   #11
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
actually it will affect air flow cuz in a vehicle with A/c all air goes through the evaporator core regaurdless of what you set the controls at. in some vehicles the evap. acts as an air filter for the system for ones that don't have a cabin air filter. if you've ever looked at the a/c lines anytime with the a/c running you'll notice moisture plus the low pressure side line gets quite cold. and the evaporator is colder then that.
Old December 9th, 2007, 08:00 AM   #12
bigjay
bigjay's Avatar
:dunie:
Old December 9th, 2007, 11:54 AM   #13
PavementPounder
Yes, I know. The air does not travel through those lines. I believe what you are thinking of is the refrigerant line freezing, which I don't disagree with.
Old December 9th, 2007, 01:12 PM   #14
user name
keep your stick onthe ice
user name's Avatar
I though it was because at low enough air temps the refrigerant could become liquid on the low side and blow your compressor. I'm pretty sure every A/C system made today has a low temp cut out.
Old December 9th, 2007, 01:16 PM   #15
user name
user name's Avatar
If your evaporator freezes solid and is in line of the airflow through your heater box(before the heater core so it gets outside air temp) you get no flow through your heater box and therefore no heat either. GO google something else and come back when you've actually turned a fucking wrench.
Old December 9th, 2007, 02:10 PM   #16
GreaseMonkey
Pew pew!
I'd suggest not making assumptions that he has never wrenched on anything.
Old December 9th, 2007, 03:28 PM   #17
landrollover
landrollover's Avatar
Send a message via AIM to landrollover
its alright, kodiak went to UTI
landrollover is offline   Reply With Quote
Old December 9th, 2007, 04:37 PM   #18
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
hahaahah
This is funny. PP doesn't know how the AC system works.
Old December 9th, 2007, 04:42 PM   #19
PavementPounder
What you're suggesting is that enough moisture would be brought in from the outside (in air temps that we've already noted don't have much humidity in the first place) that the air passage inside the in-line evaporator would become a block of ice and not let air past it. In reality, I think the lines would freeze up before the core would suck in enough moisture to fill the air cavities with solid ice and completely block airflow. The purpose is along the lines of what Scooter mentioned - to keep the refrigerant lines and compressor from being damaged. Maybe I don't understand it as well as others do and maybe it was a different configuration, but I've had A/C systems freeze on me and they didn't stop blowing air.
Old December 9th, 2007, 04:48 PM   #20
GreaseMonkey
Pew pew!
So where's the website you found that on off of your Google search? :tonka:
Page generated in 0.44956 seconds with 83 queries
