Ford HP60 Trade for Chevy LP60 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 6th, 2007, 10:01 PM   #1
bbaXJ
Yooper In Training
bbaXJ's Avatar
Default Ford HP60 Trade for Chevy LP60
I have a complete 88 Ford SRW kingpin HP60. Complete as in hub-to-hub everything is there, even calipers that'd be for cores. It's crusty but solid, as are most HP60s.
I'm running a passenger drop t-case and my front driveshaft is a mile long so rather than paying to get this retubed I'm considering getting a passenger drop kingpin 60 instead. Must be SRW Chevy, complete, and with non-neckdown shafts(1980+ I believe).
So I'm considering trading my HP60 for a Chevy LP60 and a little cash/parts. If yours is in better condition, has spare parts, a locker, 4.88 gears, high-steer arms, etc this would obviously influence the trade value.
I'm located in Highland and would prefer not to go far to make this happen, but lemme know what you've got regardless. This isn't a for sure thing yet but pretty likely if the deal looks good.
This is the axle:
bbaXJ is offline
Old December 7th, 2007, 12:34 PM   #2
ttocsnekia
Fawkin' Noobs
ttocsnekia's Avatar
Are any of the calipers good Sean?
ttocsnekia is offline
Old December 7th, 2007, 12:35 PM   #3
ttocsnekia
Fawkin' Noobs
ttocsnekia's Avatar
I will give Spooner a call, he might have one. And I will make some other calls
Old December 7th, 2007, 01:24 PM   #4
ttocsnekia
Fawkin' Noobs
ttocsnekia's Avatar
Found this
dana 60 front 513 gear spool yukon 35 spline shafts hydraulic cylinder no brakes rotors cals
14 bolt with pinon brake
44" boggers on 8 bolt rims all for $2,800
Old December 7th, 2007, 02:53 PM   #5
bbaXJ
Yooper In Training
bbaXJ's Avatar
Originally Posted by ttocsnekia View Post
Found this
Not a bad price for what it is but all I'd need from that is the front axle.
You talkin about Zach? He's the one I got this axle from to begin with so I doubt he needs it back. I'd prefer not to drive that far for the swap.....I'd spend nearly enough on gas to negate the savings on the axle.
Good for cores but that's about it. The calipers and dust shields are pretty crusty, the rest is just surface rust.
bbaXJ is offline
Old December 7th, 2007, 03:49 PM   #6
ttocsnekia
Fawkin' Noobs
ttocsnekia's Avatar
I asked him is he was willing to split. Will let you know.
Scott
Page generated in 0.24843 seconds with 41 queries
