what weight oil 360..... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 6th, 2007, 01:57 PM   #1
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Default what weight oil 360.....
What should i run in my 360? its got less than 1000miles on it. Its in my jeep... was thinkin 5w30 w/ quart of lucas oil stuff. Don't plan on driving it much this winter.
Old December 6th, 2007, 06:08 PM   #2
frdboy
frdboy's Avatar
5w30 will be fine, I am not a huge fan of additives just use some good quality oil.
When you drive it make sure you get the oil temp up by driving it, don't just start it and let it run a few minutes and then shut it off.
Adam
Old December 6th, 2007, 06:22 PM   #3
Gr8wht2000GMC
Gr8wht2000GMC's Avatar
Im with frdboy...additives arent necessary,especially in a new motor. Buy good oil and change it religiously at 3000mi. There is no mechanic in a can. The only time I would condone an additive is an old, sloppy engine that you cant or dont want to rebuild. Regular care is a miracle worker.My dad has driven the same 1995 Pontiac trasnport for 350,000 with nothing more than regular wear parts.
Gr8wht2000GMC is offline   Reply With Quote
Old December 6th, 2007, 06:33 PM   #4
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
I run Mobil One, 10w30 in the summer and 5w30 in the winter. Sometimes I've ran either/or in either season, and I don't notice any difference.
Old December 6th, 2007, 09:32 PM   #5
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
i agree with above. there is no need for oil additives in a new engine. a good quality 5w30 oil will work for both seasons. i personally use pennzoil in all my vehicles, but truthfully oil is oil. unless comparing dinosaur juice to manmade stuff there is no noticible diffrence.
Old December 9th, 2007, 11:12 AM   #6
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
thanks guys. I have never been one that used additives. I work at advance auto and everyone thinks these additives will stop a blown head gasket.
I just need to get off my ass and pull the jeep in the garage, fire up the furnace and wait till it gets warm
Old January 19th, 2008, 02:46 PM   #7
DodgeDude99
Lucas should never be used.
do a web search for "Frank is the Oil Guy" and "Lucas" and it will change your mind.
DodgeDude99 is offline   Reply With Quote
Old January 26th, 2008, 10:43 PM   #8
user name
keep your stick onthe ice
user name's Avatar
If you don't have a roller cam (88 or 89 is when the switched to roller in the 360) which I don't think you do if I'm remembering correctly from your other posts you should use an oil designed for use in a diesel. The oil made for cars today(including most synthetic) is lacking the addatives that keep your cam from wearing out(even though it would probably take a long time). most of the oils that meet that spec are a 15w40, thats what I run in my old style engines without roller cams. if it's a newer engine than I think you have run whatever it doesn't matter.
Old January 26th, 2008, 11:13 PM   #9
71jeepster
Glad I'm not Gay J. Hall!
71jeepster's Avatar
Send a message via Yahoo to 71jeepster
I didn't know it was safe to run oil for diesel in a gas engine! If that's the case I can get that by the gallon, free! Might start running that in the old XJ!
71jeepster is offline   Reply With Quote
Old January 26th, 2008, 11:23 PM   #10
83CJ7
Got 360?
83CJ7's Avatar
I'm with GreaseMonkey. I run Mobile 1 syn in my 360 and Run 5 30 all year.
83CJ7 is offline   Reply With Quote
Page generated in 0.20827 seconds with 53 queries
