Danas! ***Pics Up*** SOLD please Delete Thanks - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 4th, 2007, 10:58 AM   #1
dcbur2
Burkeoo
Send a message via MSN to dcbur2
Default Danas! ***Pics Up*** SOLD please Delete Thanks
I Have A dana 44 front and Dana 60 rear
Make me an offer the gears are 3 54!
It is 8 lug out of 79 ford
The new price is 400 obo. Thanks
Thanks Derek!
dcbur2 is offline
Old December 4th, 2007, 11:28 AM   #2
PavementPounder
PavementPounder's Avatar
Are these newly rebuilt?
PavementPounder is offline
Old December 4th, 2007, 09:04 PM   #3
dcbur2
Burkeoo
Oh i would also trade for some wheels if anyone had any i need 12 x 16.5 classic 2, 8 lug thanks
dcbur2 is offline
Old December 4th, 2007, 09:33 PM   #4
NewGuyYJ
NewGuyYJ's Avatar
Pics? And where in this crap-tastic state?
NewGuyYJ is offline
Old December 4th, 2007, 09:38 PM   #5
dcbur2
Burkeoo
Will get pics tomorrow!
And im located in addison near jackson
come and get them
Thanks
dcbur2 is offline
Old December 4th, 2007, 09:38 PM   #6
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Thanks for the location.
Everyone else- if you think the price is too high, either PM him, or move on.
Cooter is offline
Old December 7th, 2007, 03:19 PM   #7
dcbur2
Burkeoo
Here are the pic i said i would get up for you guys sorry it took me a little bit longer then i said.
Thanks
Derek
ID:	17941   Click image for larger version
dcbur2 is offline
Old December 7th, 2007, 04:17 PM   #8
dcbur2
Burkeoo
New info these are also SOA bolt-in for YJ's.
dcbur2 is offline
Old December 7th, 2007, 04:23 PM   #9
NewGuyYJ
NewGuyYJ's Avatar
You mean the spring perches have been rewelded to match the width needed for a YJ? If so, I just might be all over this
Edit: And how are the brakes (pads, calipers, rotors, etc), tires come with, general condition (diff been opened, taken out of your yj after being ran for x amount of years)?
NewGuyYJ is offline
Old December 7th, 2007, 04:24 PM   #10
dcbur2
Burkeoo
Accutly i have no idea i have gotten the info from Pavement and but what he said yes it matches the width, but i really dont know
EDIT: Brakes there are none. rotors are good dont know bout calipers. if you want the tires i pm you. the diff has been opened oil still in it. and they didnt come out of YJ out of ford 79. they been ran for about 6 years at the most then sat and then we ran for about 6 months.
dcbur2 is offline
Old December 7th, 2007, 04:58 PM   #11
PavementPounder
78-79 F-250's have factory SOA perches that match YJ perch width. This particular axle combo is great if that's the amount of lift you are after. The front axle is reverse-cut, driver-drop, has large diameter/thick wall tubes, flat-top knuckles, and dual-piston calipers. If you want to see examples, read through this thread and check out the pics:
http://www.greatlakes4x4.com/showthread.php?t=665
Old December 7th, 2007, 05:04 PM   #12
dcbur2
Burkeoo
Thanks for the help!
dcbur2 is offline
Old December 7th, 2007, 05:19 PM   #13
Toivo
Feel lucky?
Toivo's Avatar
The front axle is a D44HD, 8 lug 44. low pinion housing, 2.5in OD axle tubes, 1/2 wall axle tubes IIRC.
Rear is a D60 as stated, prolly with stock 1.5in 30 spline shafts, IIRC.
Toivo is offline
Old December 7th, 2007, 05:25 PM   #14
dcbur2
Burkeoo
and thank you for the help!
dcbur2 is offline
Old December 7th, 2007, 06:10 PM   #15
NewGuyYJ
NewGuyYJ's Avatar
I seem to recall either having to outboard the spring hangars or rewelding the perches inwards, but if you say so...
Originally Posted by Toivo View Post
The front axle is a D44HD, 8 lug 44. low pinion housing, 2.5in OD axle tubes, 1/2 wall axle tubes IIRC.IIRC.
First, PP says its reverse cut, then Toivo says low pinion, aren't those opposite?
NewGuyYJ is offline
Old December 7th, 2007, 06:19 PM   #16
PavementPounder
Yes. He's wrong. Although D44HD's had ribs, if you look at the picture the ribs at the centerline of the tubes are clearly below the pinion. The axle also has open knuckles, which LP D44HD's didn't have.
Old December 7th, 2007, 06:22 PM   #17
NewGuyYJ
NewGuyYJ's Avatar
Alright, that's what I thought too, but then again, I thought you had to work the perches :tonka:
OP: you have a pm
NewGuyYJ is offline
Old December 7th, 2007, 06:23 PM   #18
PavementPounder
You're thinking of a different axle or a different vehicle (like a CJ).
Old December 7th, 2007, 09:08 PM   #19
ttocsnekia
Fawkin' Noobs
ttocsnekia's Avatar
If you want to get technical, it is off by 1/2" as far as being bolt in. Most people either redil the holes that the pins line up in, or force the leafs into place.
Scott
ttocsnekia is offline
Old December 7th, 2007, 11:14 PM   #20
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
SOOOOOOO WRONG you lose :tonka:
77 44hd were open knuckle, That jeep you posted has one and so does Tovio.
Jeepaholic is offline
Page generated in 0.43661 seconds with 84 queries
