Do I have a case with interco tire? - Page 6 - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > Classic Threads
Classic Threads Threads to good to lose! Now all found in one forum!
Old January 8th, 2008, 09:39 AM   #101
PavementPounder
PavementPounder's Avatar
If they are smaller then that, then it is false advertising.
In the Engineering world, we call that shrink rate and its just a fact of life. Measure that same tire at a different ambient temperature, and it'll be a different size. Change the material compound slightly, and it'll be a different size. The more rubber mass it has, the more the difference will be. That's why the OD's get farther and farther off as the complexity of the mold increases on the more aggressive tires. Its also the reason why you don't see such differences in the OD's that other manufacturers publish. Their tires are just not as heavy, complex, or agressive as some of STOA's designs.
Old January 8th, 2008, 12:16 PM   #102
clarkstoncracker
lol
clarkstoncracker's Avatar
Originally Posted by UP_ROKTOY View Post
This is standard practice when it comes to any tire.
Go measure any tire, take tires of different brands, all sizes, they wont be exactly the same.
Further I am sure with tires such as interco's that each batch ends up slightly different. The advertised size is probably the average of the bunch.
How many swampers have you had to send back becuase they were not round? 2 for me.
It happens, do more research before you buy the tires to understand what you are getting, realize they don't all measure up exact and deal with life.
You can't possible be right in this situation. A company is advertising an EXACT SPEC (go look at their page) and my tires were 6% off. Sorry, no matter what :chiefwoohaw: you give, you're wrong, and they are giving out totally false information.
Old January 8th, 2008, 12:17 PM   #103
clarkstoncracker
lol
If thats the case, then they should have a window of sizes, or a %+/- variable in their spec pages.
The only time you see this kind of bullshit advertising is when reading poorly written jap manuals for cheap electronics.
Old January 8th, 2008, 12:23 PM   #104
Mr. Beefy
BFT!
Mr. Beefy's Avatar
So did you get new tires or still in the process?
Old January 8th, 2008, 12:25 PM   #105
PavementPounder
I agree, but then they'd have to admit to causing a % +/- in any given vehicle's speed.
Old January 8th, 2008, 01:31 PM   #106
kickstand
circling the drain
kickstand's Avatar
Go read what PP posted, it would be impossible due to that to give you an EXACT diameter, too many variables come into play. Rim size, temperature, manufacturing processes, air pressure, vehicle weight, etc. Before you get all huffy about that to think about it, are all 8" wheels exactly 8"? I bet not, some measure to the outside of the wheel, others measure to the inside of the bead where the rubber meets the rim, others measure from the outside of the outer bead to the inside of the inner bead, etc.
There is going to be some sort of variance. Though 6% seems excessive, maybe that is within their tolerances?
What are the chances that there IS a 37 irok like the one you purchased that IS the advertised height?
What are the chances you did a search on the subject before spending your money to realize it's a known fact?
False advertisement or not you not knowing tires are not the same as the number on the sidewall or the website is like someone not reading itrader. You should have known better and asked around. Plain and simple.
Now I do agree they should have a more factual number, but I don't think it's that easy because of all the variables involved. With that said I just spent the last 10 minutes looking for some sort of disclaimer and they don't seem to have one in regards to their advertised size. So in that aspect your right, but by being ignorant, your still wrong.
Of course in the mean time I came across this awesome ford truck and had to post it for all to see.
Old January 8th, 2008, 01:37 PM   #107
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
how is 5 weeks 2 months now
Old January 8th, 2008, 01:40 PM   #108
clarkstoncracker
lol
because I purchased the tires 17 days before I had them mounted :)
Old January 8th, 2008, 01:47 PM   #109
busyfixin
Balls Deep
busyfixin's Avatar
49's and air shocks? im pretty sure they would be overheated by the time you needed that sweet swaybar. on another note, i was pretty happy to find that the 37's were real close to 36" because i know the 36's are close to 37. i needed a 35-36ish tire and wanted an irok, thankfully they make it, they just call it a 37.
as for all this exact tire size talk, it is deffinitely a lot gay. i hear enough of it in the drag racing world, where they still have this issue.
Old January 8th, 2008, 01:51 PM   #110
Flexin' XJ
Flexin' XJ's Avatar
Maybe Interco should put a disclaimer on their site stating "Due to the manufacturing process, actual tire size may differ than advertised dimension."
I should sue McDonalds for my double quarter-pounder only weighing one third of a pound. Wait, they get away with it with the "Weight measured before cooking" disclaimer.
Flexin' XJ is offline   Reply With Quote
Old January 8th, 2008, 01:54 PM   #111
hosejockey4506
Visiting Admin
Originally Posted by busyfixin View Post
49's and air shocks? im pretty sure they would be overheated by the time you needed that sweet swaybar. .
those are triple bipass shock dummy
Old January 8th, 2008, 01:56 PM   #112
kickstand
circling the drain
kickstand's Avatar
That's what I was looking for when I came across that sweet truck.
Old January 8th, 2008, 01:57 PM   #113
clarkstoncracker
lol
Obviously you're not in customer service or sales. I guess being ignorant means spending a thousand bucks on something that is not anywhere close to what its advertised to be. I guess I'm pretty ignorant. Thank god my employees don't have your mentality, because they sure wouldn't last long around here.
Old January 8th, 2008, 02:04 PM   #114
PavementPounder
Uh, yes?
If I told you I had a 401 (that was really a 304), which you took my word for, picked up, paid for, and left with, I think that would make you fairly ignorant. :tonka:
Old January 8th, 2008, 02:08 PM   #115
clarkstoncracker
lol
Uh, yes?
So yes, if I was at the tire plant to buy my tires, and I measured them there, I probably wouldn't buy them, very good point. I'll have to start purchasing everything where they are being made.
if you were a real business, and you advertised a product as "X", and I purchased it, and received "Y", you're going to fix it, or my lawyer will fix it for you :)
Old January 8th, 2008, 02:08 PM   #116
TopHeavy
Yikes!
TopHeavy's Avatar
What do you mean "not anywhere close...". They are within 6%. I wish my work was only held to a +- 6% tolerance.
:miff:
Buy My CJ7
TopHeavy is offline   Reply With Quote
Old January 8th, 2008, 02:10 PM   #117
clarkstoncracker
lol
:miff:
Maybe I will up all my generator stats 6% to get more sales. I know, I'll take a 250kw generator and list it as a 265kw generator. That sounds like a fine idea, and I can use up_roktoy's logic that my customers are ignorant if they buy it.
Old January 8th, 2008, 02:11 PM   #118
PavementPounder
Well, true - but I'd still probably laugh my ass off...
...if it was you.
Old January 8th, 2008, 02:14 PM   #119
TopHeavy
Yikes!
TopHeavy's Avatar
Makes sense to me.
Buy My CJ7
Old January 8th, 2008, 02:16 PM   #120
clarkstoncracker
lol
Makes sense to me.
I just spoke with the owner of the BP, I informed him to dispense 94% of a gallon, but make his pumps say they dispensed a gallon. This will both reduce his net cost, as well as making his customers ignorant.
I love this, I'm going to spread the joy of screwing over people!
Page generated in 0.55253 seconds with 84 queries
