Help,......Ford Tranny Guys. - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 7th, 2007, 11:36 AM   #21
FORD FLARESIDE
Headed to Nationals 2017!
FORD FLARESIDE's Avatar
I think I'm going to Pin a $50 bill on my Peg Board in my Garage. Then invite all the Cheapthrill's guys(and gals) over.
The first one to find out what is causing the problem, gets to keep the $50.
:tonka::tonka::tonka::tonka::tonka::tonka::tonka:
Old December 7th, 2007, 11:37 AM   #22
FORD FLARESIDE
Originally Posted by farm_boy View Post
ok i have a manual for this truck with a wiring satmatic in it if you want me to take a pic and post it i will
Is it the Manufacturers Manual or the Hanes?.............I have the Hanes.
Old December 8th, 2007, 02:35 PM   #23
TurdBronco
Did you try the gear selector switch?
Old December 9th, 2007, 10:36 AM   #24
General
General's Avatar
Ok twist my arm what day and time?
General is offline   Reply With Quote
Old December 15th, 2007, 05:17 PM   #25
FORD FLARESIDE
Okay, I'm about ready to give this piece of heap away.........................
You can't buy half of the sensors from the autoparts stores, if you call Ford, they don't have a clue on what you are talking about...............
and after 30 hours on my back under this stupid thing, it is still not working.
The throttle positioning sensor (TPS) is located on the bottom side of the Plenumn(another wonderful Ford design) what does the TPS have to do with the transmission shifting? Or was I sold down the river by a parts guy, so he could sell a non returnable electric part. I don't want to have to tear the whole top of this motor apart to change this sensor if I don't have to.
Old December 15th, 2007, 05:51 PM   #26
Fraser
Fraser's Avatar
it should be on the throttle body, thats where its located on the 2.9's, never had a look at a 302 tho
Old December 15th, 2007, 07:26 PM   #27
frdboy
frdboy's Avatar
Have Josh put it on a trailer and get it over here
Old December 15th, 2007, 08:19 PM   #28
FORD FLARESIDE
I will bring it down this week. Thank You
From what Josh tells me, you are a Miracle Worker.
Old December 16th, 2007, 08:11 PM   #29
jontboudrie
jontboudrie's Avatar
Default trans problem
did you check all the fuses my truck will pop a fuse about once twice a year
shifts all crazy put in new fuse good to go!! fuse is in the dash .
my truck is 94 4x4 250 diesel.
hope that helps! good luck !
jontboudrie is offline   Reply With Quote
Old December 17th, 2007, 06:08 PM   #30
FORD FLARESIDE
I checked all of the fuses in both fuse boxes, but they are good,....anywhere else to check?
Old December 17th, 2007, 06:10 PM   #31
FORD FLARESIDE
Originally Posted by jont[COLOR="Red"
boudrie[/COLOR];861330]did you check all the fuses my truck will pop a fuse about once twice a year
Is Boudrie your last name,.........this was my grandma's maiden name.
Old December 17th, 2007, 10:39 PM   #32
General
General's Avatar
Its on the throttle body I had to replace it on my 96 a few years ago. The thing is if the tps was bad the O/D off light on the shifter sould flash. What stealership did you call?
Old December 18th, 2007, 10:41 PM   #33
FORD FLARESIDE
Yours:tonka::tonka::tonka:
My O/D hasn't Blinkied in about 10 years.................maybe that is the problem.
Old December 19th, 2007, 08:47 AM   #34
General
General's Avatar
Try pushing the button and see if it lights up with the truck running. What ever happend with the scan that you did on it?
Old December 19th, 2007, 10:17 AM   #35
FORD FLARESIDE
No Codes at all, He tried 4 different times.
Old December 19th, 2007, 11:35 AM   #36
General
General's Avatar
When can I come look at it again?
Old December 19th, 2007, 01:19 PM   #37
FORD FLARESIDE
Thursday, or Friday night this week,...................after that its being hauled to the scrap yard.............
Old December 19th, 2007, 08:15 PM   #38
General
General's Avatar
Well if its going to scrap I'll just take it home with me when I come get my power stroke frome you. :tonka: Friday night would work best for me Pm or call me with a time.
Old December 19th, 2007, 08:37 PM   #39
jontboudrie
Default last name
yeah thats it boudrie, have family all over i guess only associate with a hand full not a close family.
Old December 19th, 2007, 08:39 PM   #40
FORD FLARESIDE
I'll call you......
Page generated in 0.55239 seconds with 83 queries
