Help,......Ford Tranny Guys. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 3rd, 2007, 04:27 PM   #1
FORD FLARESIDE
Headed to Nationals 2017!
FORD FLARESIDE's Avatar
Default Help,......Ford Tranny Guys.
Okay short version, and I need Ideas.............
E40D Tranny behind a 302, Had issues with it being locked in 4low, and found out that the pivot bolt for the linkage had backed out.
This tranny and T-case were built two years ago, and has a lock up torque convertor, shift kit, and S.S. Planetary gears.
I finally got to test drive it on the road tonight, (after sitting for 9 months) and it now shifts through all the gears, but,........it shifts at 4K RPM instead of 2K and when it does shift it just about puts your head through the back window.
In over drive it is turning about 3800RPM at 55 mph (355gears) when it should be at aout 1800. It doesn't sound like variable slipping it just is steady at 3800.
Please help, ......I do have someone who will look at it for me (which I still intend on doing) but I really don't feel like going through $50 in gas to drive it over to him, at that high of RPM.
Is there a vacuum hose or electronic item I need to look for that handles Kick down, I'm not sure where or what it is.
Old December 3rd, 2007, 08:24 PM   #2
Tom
Because racecar
Tom's Avatar
it sounds like a faulty speed sensor or tps
Old December 3rd, 2007, 09:26 PM   #3
chris1044
chris1044's Avatar
X2.....IIRC everything on that truck is electronic.....
Do you have access to a scan tool?? Data stream could quickly rule out/verify if this is the cause
Old December 3rd, 2007, 10:19 PM   #4
FORD FLARESIDE
No, I don't have a scan Tool.....................can anybody help here?
I did some Web Searching, and from what I am reading, it could be the MLP, the TPS, or the Sensor on the Rear Diff. Can anybody check these for me?
In the trucks current state, I will not be able to drive it. If need be, I will load it on the trailer and bring it to you.
Adam,.......help................................ ........you are in need
Old December 3rd, 2007, 10:44 PM   #5
chris1044
chris1044's Avatar
Well...before you do anything like that, you can check the TPS or sensor on the rear diff (VSS).
Do you have a volt meter?? If so (it'll need to do both AC and DC) you can check the sensors - post up the year of the truck and I'll look into wiring diagrams/values for you tomorrow if (when) I've got time
Old December 3rd, 2007, 10:47 PM   #6
FORD FLARESIDE
I do have a meter, and believe it or not it's actually and Auto-Meter.
(unfortunately its not used very much)
It is a 1992 4x4 with the 5.0 and E40d
Old December 3rd, 2007, 10:54 PM   #7
chris1044
chris1044's Avatar
Alright, well, tommorow I'll find the data on the sensors....but for the most part, you can check a couple things - Key on engine off for all these tests
TPS - should get a fluctuating DC voltage from roughly 0v to 4.5 volts (higher voltage the more the throttle is open)
VSS - Jack the rear wheels up, put it in neutral, connect the volt meter across the two prongs at the sensor reading AC volts. Spin the back wheels, and the voltage should increase with tire speed.....
Like i said, I'll try to get the wire colors/actual data tommorow.....
Old December 4th, 2007, 12:37 PM   #8
chris1044
chris1044's Avatar
Wish I could help ya out more....but, Fords service site doesn't go back to 92
What I posted above stands though.....you need to verify that the TPS and VSS are working properly with a volt meter (since you don't have access to a scan tool).
Hopefully someone will post up the colors at the TPS, and the terminals at the PCM so you can make sure the PCM is getting the signal as well....
Old December 4th, 2007, 12:45 PM   #9
FORD FLARESIDE
The three parts in question are going to cost me about $150 total..........which I don't want to spend money on, but I do have the resources for them.
What is the chance that there is an issue with the Harness itself verses MLPS, TPS, or the VSS? Did Ford have a lot of problems with their harnesses......anybody?
I read on a Ford website that the MLPS, may not even send a code, if it is bad. So do I spend the money to have someone scan it?
I can start doing continuity test on the wiring harness, but I would like to use the truck this winter for plowing........:tonka:
Old December 4th, 2007, 01:33 PM   #10
chris1044
chris1044's Avatar
Thats why Data stream becomes so important.....if the data on the scan tool checks out OK, you can assume that the sensor, wiring to the PCM, and the PCM are good......
Without a scan tool, your basically stuck checking voltages
Old December 4th, 2007, 06:41 PM   #11
General
General's Avatar
Pm sent.
General is offline   Reply With Quote
Old December 4th, 2007, 08:45 PM   #12
TurdBronco
I have had a wire corrode in the trans wire harness.
You could replace the black plastic thingie on the drivers side that tells the trans what gear you've selected. I've had that go bad also. It was 10 or 15 bucks.
Old December 6th, 2007, 09:10 AM   #13
frdboy
frdboy's Avatar
If it comes to you having to trailer it I will drive out there and take a look
Adam
Old December 6th, 2007, 09:32 AM   #14
farm_boy
hicktown
farm_boy's Avatar
i had the same thing and it turned out to be a speed senor check your speed senor man
farm_boy is offline   Reply With Quote
Old December 6th, 2007, 10:48 AM   #15
FORD FLARESIDE
I have someone coming tonight to run a scan on the truck.
I will post what we find Later tonight.
Old December 6th, 2007, 10:58 AM   #16
farm_boy
hicktown
farm_boy's Avatar
good deal i had a truck like this at one time ow that was a nice
Old December 7th, 2007, 10:50 AM   #17
General
General's Avatar
Update? :dunie:
Old December 7th, 2007, 11:09 AM   #18
FORD FLARESIDE
:miff:Ford:stan3:
Well, it's not sending any codes..........so now I get to replace the MLPS and have the guy come back and scan it again...............
Anybody want to buy a Ford?
Old December 7th, 2007, 11:32 AM   #19
General
General's Avatar
Time to get the multimeter out.
Old December 7th, 2007, 11:35 AM   #20
farm_boy
hicktown
farm_boy's Avatar
ok i have a manual for this truck with a wiring satmatic in it if you want me to take a pic and post it i will
Page generated in 0.56123 seconds with 83 queries
