SOLD - FSJ NT (Wagoneer) D44's - $400 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 3rd, 2007, 04:06 PM   #1
PavementPounder
PavementPounder's Avatar
Exclamation SOLD - FSJ NT (Wagoneer) D44's - $400
The front is mid-70's passenger drop LP with flat-top knuckles, a factory OTK tie-rod with inverted-t steering, 3.xx gearing, 6x5.5", 100% complete.
The rear is a centered D44 from the 80's with 3.xx gearing, factory panhard bar mount, 6x5.5" 100% complete.
WMS is 60.5", perches are at about 32". Great set of medium-duty axles for a CJ.
$400.
SOLD.
PavementPounder is offline
Old December 3rd, 2007, 11:33 PM   #2
PavementPounder
Price adjusted.
Old December 5th, 2007, 02:21 PM   #3
88yj
collecting parts
88yj's Avatar
Send a message via AIM to 88yj
Is that the front axle I owned for a while?
88yj is offline
Old December 5th, 2007, 02:54 PM   #4
PavementPounder
Yes. I still have the matching offset rear.
Old December 5th, 2007, 03:10 PM   #5
88yj
collecting parts
88yj's Avatar
and I still have no use for the pair :tonka: Good luck with the sale.
88yj is offline
Old March 10th, 2008, 06:56 PM   #6
PavementPounder
Hey, I've got a great idea! Let's all go buy super-wide shit because its "cheaper" and then spend more than these axles cost to get the full-size set narrowed and probably still not even have flat-tops! Yay! :tonka:
Old March 31st, 2008, 06:26 PM   #7
93bowtie
wheeling a Xj now
93bowtie's Avatar
hey
would you sell just the front axle ?
if so how much ?
thanks
93bowtie is offline
Old March 31st, 2008, 06:28 PM   #8
PavementPounder
Originally Posted by 93bowtie View Post
hey
if so how much ?
thanks
Not splitting the pair.
Old April 1st, 2008, 11:11 AM   #9
pumpshop4
USMC
pumpshop4's Avatar
Would these bolt right in a cj or would the perches need to be moved? Would this be alot better set up then the 20/30 set up I am putting together now?
pumpshop4 is offline
Old April 1st, 2008, 11:18 AM   #10
PavementPounder
Rear perches need to be moved. On the front, either the springs need to be outboarded, a full-width bracket kit needs to be purchased (I have a Poison Spyder kit if you want to see it), or the long side cut down to get the passenger spring off the diff. Or you could 4-link it and eliminate the leafs with coil-overs. Most people outboard the springs or buy the kit.
This would be an overall heavier-duty setup than what you have, but you'd need to gear it. In your case, you would want the set with the FSJ C20 rear that I have instead of the D44 rear, as it is stronger and your CJ C20 differential parts swap right in. Then you would only have to buy gears for 1 axle.
Old April 1st, 2008, 11:24 AM   #11
pumpshop4
USMC
pumpshop4's Avatar
I didn't see the set with the c20 posted just the c20 by its self.
Old April 1st, 2008, 12:10 PM   #12
PavementPounder
Yes. Its by itself, but can be paired with the front instead of the D44 rear for the same price.
Old April 1st, 2008, 01:04 PM   #13
pumpshop4
USMC
pumpshop4's Avatar
What is the front brake- lockouts situation? The rear would be the same for my current rims but what would the front be?
Old April 1st, 2008, 01:33 PM   #14
PavementPounder
FSJ axles are 6x5.5". The rear is not the same, either. You will need different rims.
Not sure what you are asking relative to the brakes and lockouts. Brake lines are just a matter of using the right fitting and these axles do not have lockouts. They have drive slugs. Lockouts fit right in place of them. Very simple installation.
Old April 1st, 2008, 01:35 PM   #15
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
If you want to narrow the front I have done two and it is quite easy to do and then will bolt in
Jeepaholic is offline
Old April 1st, 2008, 02:17 PM   #16
pumpshop4
USMC
pumpshop4's Avatar
Ok so if I had both the Fsj axles I would need to move the rear perches . Buy a full width kit ( about $400) for the front and lock outs. Then change to a 6x5.5 rims. As I want to change to a t-18 The gearing could be done later. Later I want to put lockers and gears in. Would sell my current axles and parts to go down this path.Just hate to put alot of money into the 20/30 setup just to want to upgrade later.
Old April 1st, 2008, 02:22 PM   #17
PavementPounder
Well, you haven't spent much on your axles so far and are already geared.
What you said pretty much sums it up, though.
Old April 17th, 2008, 11:43 AM   #18
PavementPounder
Sale pending.
Old May 13th, 2008, 10:29 PM   #19
PavementPounder
SOLD.
Page generated in 0.24570 seconds with 80 queries
