1995 XJ Build - BDS Long Arm, Cage, Durabak, etc - Page 7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Closed Thread
Old December 18th, 2007, 11:34 PM   #121
One Arm Steve
I was born in the desert
One Arm Steve's Avatar
Looks like them rear shocks are going to bottom out (not much down travel). My springs have a lot more leaves than yours and there is at least 7 inches of down travel when I'm hitting the rough stuff. jm2c
One Arm Steve is offline
Old December 19th, 2007, 12:11 AM   #122
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
You mean up travel? Like the axle moving up? There is just short of 8 inches of up travel on the shock there and it will be bump stopped. Plus the tops are moved in so there is even more travel available.
Buggy_Tim is offline
Old December 20th, 2007, 05:10 PM   #123
One Arm Steve
Yep up travel :tonka: and bump stops will help. I don't use them but have a larger spring pack and am amazed how much the axle moves.
Old December 29th, 2007, 03:35 PM   #124
bigtruckman
One shot, One Kill
bigtruckman's Avatar
Any updates on this project??? BTM
bigtruckman is offline
Old January 4th, 2008, 02:17 AM   #125
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Yes, but not much you can really "see". Christmas break has slowed progress. I got lots of welding in the rear wheel wells done. The other day it too 5 hours to get the front driver's seat mounted....long story...Welded up the front part of the cage. Drilled some of the front bumper mount holes. Lots of cleaning and sanding has been done also.
Rear wheel wells all welded up. Mig welded the seam back together from the outside, then brazed it from the inside, then applied panel bonding epoxy on the inside. Will be plenty strong.
Old January 5th, 2008, 11:17 AM   #126
bitchofanxj
Are you cooool maaaann?
bitchofanxj's Avatar
Very nice job on the wheel wells. When you re-paint the exterior are you going to just do the same color again?
bitchofanxj is offline
Old January 5th, 2008, 12:31 PM   #127
jeeperbrian
GLFWDA member
x2, looks great. much cleaner than some stuff ive seen
jeeperbrian is offline
Old January 5th, 2008, 01:33 PM   #128
ddeadserious
ddeadserious's Avatar
he's herculining from the main body line down.
and x3, the wheelwells look excellent, much nicer than the cut and fold.
ddeadserious is offline
Old January 5th, 2008, 10:10 PM   #129
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I am not damn it.:tonka:
Herculiner is for girls.
Da ONLY way to go.
Old January 5th, 2008, 10:11 PM   #130
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Oh, and thanks for the kind words on the wheel wells. It was a team effort....Turtle and I worked on it for a LONG time.
Old January 6th, 2008, 12:46 AM   #131
ddeadserious
Da ONLY way to go.
Sorry! It's just kind of a universal word for bedlining for me now.
Did those blue rollers come with the Durabak, or did you buy them somewhere?
Old January 6th, 2008, 01:28 AM   #132
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
No, they come with the product. You get 2 rollers with a gallon of textured. The smooth Durabak requires no special rollers. You can use any roller you want. Both can also be applied with a brush. Both can be sprayed also but you need a special gun for that. The Xylene was purchased locally though.
Old January 6th, 2008, 01:28 AM   #133
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Ok, got more done.
Pulled all the crappy headliner material off the headliner.
Then is looked like this. I soaked it all down with fiberglass resin.
Tomorrow i'll glue the new headliner material onto it. I got actual headliner material from Jo-Ann Fabrics.
While that was drying and the paint for the roll cage was drying we started the sliders/steps.
The part that will be bolted to the pinch weld. 15 bolts will hold it on. Prolly overkill but whatever. LOL
2x2 3/16 box tube.
Bent up the step part. This will also pull double duty to keep the body away from things. Tube is 1/4 wall.
The roll cage toll be plated through the floor and then welded to the cross bars that hold the sliders on to tie it into the frame a bit. That's more the reason we went with so many bolts.
Not the bestest welder, but I am learning. I have a good teacher, he's 17 years old. hahahaha
This is the basic design. There will be one more leg in the rear for a total of 3.
Old January 8th, 2008, 03:13 PM   #134
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Timmay,
Why bolt the sliders on and not weld them?
@clarkstoncracker
ScOoTeR is offline
Old January 8th, 2008, 05:31 PM   #135
fukkinrizzo
Chrome Trucker Chicks Rul
fukkinrizzo's Avatar
cool build
I like this too:
fukkinrizzo is offline
Old January 8th, 2008, 05:33 PM   #136
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Because.....well......I dunno.
That's how all of them I have seen have been for the most part. Bolted to the pinch seam.
I guess so they can be removed to paint. Be hard to paint them after they were wended on.
Old January 8th, 2008, 05:35 PM   #137
steveo
In the band!
lookin nice there timbo, cant wait to see it when its done.
steveo is offline
Old January 8th, 2008, 05:43 PM   #138
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Tim.....is R osie coming over to help you with the headliner install?:tonka:
Roadhouse is offline
Old January 8th, 2008, 07:42 PM   #139
Pre4runner
Bike Dude
Pre4runner's Avatar
Looking good, nice job with the sliders
Pre4runner is offline
Old January 8th, 2008, 08:39 PM   #140
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Closed Thread
Page generated in 0.55708 seconds with 83 queries
