1995 XJ Build - BDS Long Arm, Cage, Durabak, etc - Page 14 - Great Lakes 4x4. The largest offroad forum in the Midwest
Closed Thread
Old February 24th, 2008, 08:24 PM   #261
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Durabak Time
ok, finally got round to doing the paint. The plan was to go with a "Medium Texture" this time. The YJ was full on 5 coats of textured Durabak and, although it lasted fantastic...Held up to everything including a flop on Drummond Island, it was a bitch to clean. Once cleaned, it looked like brand new but still. I wanted something durable but smoother a bit.
So it got 2 coats of textured Durabak and then 4 coats of smooth, UV stable Durabak.
Here is the first coat.
I don't remember the stages of these 2 pics.
This is a close up of what it looks like right now.
I'll pull the tape later tonight.
Buggy_Tim is offline
Old February 24th, 2008, 08:35 PM   #262
bitchofanxj
Are you cooool maaaann?
bitchofanxj's Avatar
I LIKE IT A LOT, can't wait to see what it looks like all done.
bitchofanxj is offline
Old February 24th, 2008, 08:56 PM   #263
Soy_bomb
Web Wheeling!
Soy_bomb's Avatar
Can you lay that Durabak stuff over strait up paint? Or do you have to sand/prime the surface? And I'm guessing the UV stable stuff doesn't fade?
Soy_bomb is offline
Old February 24th, 2008, 09:26 PM   #264
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
You have to scuff the paint up like anything else you are going to put on. Then clean it all with Xylene.
Yea, the UV stable stuff doesn't turn all faded and chalky like Herc and Duplicolor.
Old February 24th, 2008, 09:33 PM   #265
FlatFender
Tap Tap Splat
FlatFender's Avatar
how much of that did you use? Id like to put it on the XJ from the door molding down
FlatFender is offline
Old February 24th, 2008, 09:35 PM   #266
Soy_bomb
Web Wheeling!
Soy_bomb's Avatar
That's exactly what I was thinking.
Soy_bomb is offline
Old February 24th, 2008, 09:42 PM   #267
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
1/3 of a can of texture per coat
I have about 1/4 of a can of smooth left and I did 4 coats of that.
Old February 24th, 2008, 09:57 PM   #268
bronco4-play
Do it like you mean it
bronco4-play's Avatar
That looks good. Where do you buy that Durabak brand?
bronco4-play is offline
Old February 24th, 2008, 10:19 PM   #269
ddeadserious
ddeadserious's Avatar
That looks good, and I need to find a new alternative to herculiner.
I was vacuuming my Jeep today and came across some flaky herculiner, so just continued vacuuming, and then realized that the herc was just completely separating from the sheetmetal underneath, and I ended up effortlessly peeling up about a 2x3 ft oval of herc with bare sheet metal underneath(even though it was primered beforehand). So they lost my business and I'll be doing something else when I do the rest of the interior and this looks like a good alternative..
Where you'd get it from and what kind of prices do they have?
ddeadserious is offline
Old February 24th, 2008, 10:39 PM   #270
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
http://www.durabakcompany.com/
Lots of different colors and the price depends on color and texture and UV stable or not.
Tape removed
Tape line
Old February 24th, 2008, 10:46 PM   #271
jeepguy74
jeepguy74's Avatar
x2 i think i want to do the yj this way also
jeepguy74 is offline
Old February 24th, 2008, 10:58 PM   #272
FlatFender
Tap Tap Splat
FlatFender's Avatar
that looks really fucking good. Im excited to hear about ho well it holds up.
Old February 24th, 2008, 10:58 PM   #273
bronco4-play
Did you have to run a knife along the edge of the tape to get that edge?
Old February 24th, 2008, 11:14 PM   #274
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Normally you don't. On this edge I did...it's still real soft. It cures via the humidity but there just isn't any right now so it's drying slow.
Anyway, normally your stuff is still fully wet when you pull the tape but I did the 2 coats of the texture yesterday so it set up more. On the places that I did not put texture (inside doors) the tape pulled up with no problems and left a good line.
Old February 24th, 2008, 11:18 PM   #275
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
back in the old days before the YJ was rolled, and beat to death.
Old February 25th, 2008, 09:00 AM   #276
Gunsworth
Gunsworth's Avatar
IF the primer came up too, then that was your problem. The herc still stuck to what it was applied to. I have had issues with shit primer in the past...
Gunsworth is offline
Old February 25th, 2008, 11:04 AM   #277
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Yea I had issues in the floor of the YJ with herc coming up with the spray on zinc coating.
Old February 25th, 2008, 12:26 PM   #278
I like the red lines around the door openings.:tonka:
whiterhino is offline
Old February 25th, 2008, 01:18 PM   #279
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Looking at Duraback for my YJ... How far do you think I could get with a gallon. I was hoping to do my rockers and the interior floors.
That is looking good. :thumbsup:
jeepfreak81 is offline
Old February 25th, 2008, 02:02 PM   #280
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
That's the inside of the door jam. You don't see it when the doors are closed all the way and the weather stripping is installed.
You could prolly get 3 coats of all that out of a gallon.
Closed Thread
Page generated in 0.65420 seconds with 83 queries
