official OSTC trail run photos - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > Pictures and Video
Pictures and Video A forum for 4x4 related photos and videos
Old December 2nd, 2007, 10:39 AM   #41
clarkstoncracker
lol
clarkstoncracker's Avatar
Anthony, did you break both axles at one time? That sucks man.
Old December 2nd, 2007, 12:54 PM   #42
GOTRCKS
"RHINO ZJ"
GOTRCKS's Avatar
Yes I broke in the same location on the hill. I was crawling up nice and slow no problem or heavy pedal and I heard a small pop. At first I thought it was one of my coils adjusting, so I started going again. When I heard another pop and what sounded like grinding gears. My front tires came off the ground and I thought for sure I was going to test the rear stinger.
But the front end came back down and I started thinking that I poped out of 4 Low. So I grabbed the shifter to hold it in place, and gave it anotehr try when it grinded again and some one told me that my rear shaft was just turning and nothing was happening.
I knew it was pretty bad at that point. I backed down the hill and out of the way, dipping my rear end over a small burm, and when I went to move forward to get off the trail the only tire turning was the driver's side front, and again the drive shaft was spinning away but no rear tire turn. I got out to see what all had happened and that is when I saw the front shaft sheared off and based on what other people saw in the rear I guessed that the Pinion Gear broke inside Diff. I had to be towed a few feet forward and then I was able to limp it back to the loading area and I was able to actually drive it onto the trailer with one functioning wheel.
Thanks for your sympathy. It does suck. This is the 3rd axle break I have had since the HEMI install. I am skipping 60's and installing 2 1/2 Ton Front & Rear Steer Rockwells. My fear is I will have some 60's built for $10 to $13 grand and break them and be no better off than I am now. And I already have a set of Rockwells with in my reach at this time for a hell of alot less.
I do want to thank you and everyone else who made this trip possible for all of us to go. I want to definitely go back and see the rest of the park. Will the park be open for just an anytime trip up there? Or do we need to have a sanctioned event in order to go back?
Thanks agian,
Anthony
GOTRCKS is offline   Reply With Quote
Old December 2nd, 2007, 01:21 PM   #43
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
You do know you will have to lift it a lot higher to fit the rockwells under it right?
Old December 2nd, 2007, 02:00 PM   #44
GOTRCKS
"RHINO ZJ"
GOTRCKS's Avatar
I plan on shaving the diff cover and running bigger tires to start.
And I am leaving the installation and fabrication to the professionals.
Thanks,
Anthony
Old December 2nd, 2007, 02:11 PM   #45
Miffy
Miffy's Avatar
Send a message via Yahoo to Miffy
Nice Run Guys!! Know it had to be cold for you guys doing Safty. Good Job. We did not get to see the last hills,( Had to leave due to Grandson Breaking his arm.) We missed out on the fire talking with everyone. and that is half the fun on these gathering.
Miffy is offline   Reply With Quote
Old December 2nd, 2007, 02:13 PM   #46
Jeepaholic
Jeepaholic's Avatar
That is not the the problem fitting rockwells, shaving the diff will give you more clearance than a 60 diff. The problem is fitting the center chunk or diff. It takes alot of lift to keep it from hitting the floor/ engine, frame and still have some uptravel.
Old December 2nd, 2007, 02:17 PM   #47
mtxbigtruckin
Wheelin' Since Birth
mtxbigtruckin's Avatar
mtxbigtruckin is offline   Reply With Quote
Old December 2nd, 2007, 02:23 PM   #48
Rattler
Home Sweet Homicide
Rattler's Avatar
Originally Posted by Smiley23 View Post
I think I passed you guys on the way up - as you were getting on 75.
Me = Jackass laying on the horn and waving on the way by in the Black Tahoe.
Did you wave to my wife and I in a dark red Taco on 75 too?
Post pics later. We had to go to a wedding reception in Lansing last night. Those were some crappy roads!
Old December 2nd, 2007, 03:48 PM   #49
GOTRCKS
"RHINO ZJ"
GOTRCKS's Avatar
That is why I am leaving it up to the professionals.
Anthony
Old December 2nd, 2007, 04:38 PM   #50
Here's some pics of our snowy exit this morning. I tried it first & got stuck trying to make the sharp left turn. KB8YMF tried to to pull me first, no go. So we hooked me up in front of him & double pulled it out.
Next Ironman tried it & didn't make it any further. By then, it was iced up and he slid off even further. I tried to pull him, no go, so we hooked up his jeep & double pulled his too. About an hour and a half later we were loading up in town.
ID:	17694   Click image for larger version
ID:	17695   Click image for larger version
ID:	17696   Click image for larger version
ID:	17697   Click image for larger version
ID:	17699   Click image for larger version
ID:	17700   Click image for larger version
Old December 2nd, 2007, 05:06 PM   #51
Chip Wheeler
Chip Wheeler's Avatar
Here are a couple of pics I took. What an awesome time and thanks to everyone involved. Cant wait to go back.
ID:	17702Click image for larger version
ID:	17703Click image for larger version
ID:	17704 Click image for larger version
ID:	17705 Click image for larger version
ID:	17708Click image for larger version
ID:	17709Click image for larger version
Chip Wheeler is offline   Reply With Quote
Old December 2nd, 2007, 07:26 PM   #52
ddeadserious
ddeadserious's Avatar
Looks alot like Bull Gap terrain.
Awesome pictures guys, hope everyone had fun.
ddeadserious is offline   Reply With Quote
Old December 2nd, 2007, 08:13 PM   #53
0llllll0
JeepJohnson
0llllll0's Avatar
Default Thanks Dean-O and Everyone for a Great Time !
Special Thanks to these Guy's !
The Dogs hit the spot!
More pic's to follow...
Again thanks to Dean-O AND everyone who helped put this thing together, I hope we get the chance to do it again, and again and again.........
Ken
Jeepjohnson
"Black Foot" my CJ-7 build
Do you have a YJ ? Is the rear Frame rusted ? Check this out YJ Rear Frame Reinforcement Plates
0llllll0 is offline   Reply With Quote
Old December 2nd, 2007, 08:25 PM   #54
0llllll0
JeepJohnson
0llllll0's Avatar
Default OSTC Pic's
Here are a few select pic's...
Enjoy
ME
Nice, gotta love those old 5ers
Me again
I'll try to post some vid's up tomorrow...
Jeepjohnson
Old December 2nd, 2007, 09:03 PM   #55
tjs0461
tjs0461's Avatar
Default some more picks
tjs0461 is offline   Reply With Quote
Old December 2nd, 2007, 09:18 PM   #56
Shotgun
I only wheel with boats.
Shotgun's Avatar
What will the end result of this breeding be???
[/IMG]Heres video of the exo ZJ busting on the hill
[IMG]
[IMG]
someone else on it
Old December 2nd, 2007, 09:51 PM   #57
88XtraCabDlx
Land Cruiser
88XtraCabDlx's Avatar
My two pix
88XtraCabDlx is offline   Reply With Quote
Old December 2nd, 2007, 10:12 PM   #58
71jeepster
Glad I'm not Gay J. Hall!
71jeepster's Avatar
Send a message via Yahoo to 71jeepster
http://s201.photobucket.com/albums/a...C/IMG_0081.jpg
Who's Cherokee is this? What kind of flares are those? I like the way they look, shoot me a pm if you get a minute.
71jeepster is offline   Reply With Quote
Old December 2nd, 2007, 10:15 PM   #59
mpwal099
Stick it up your ass
mpwal099's Avatar
mpwal099 is offline   Reply With Quote
Old December 2nd, 2007, 10:18 PM   #60
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Originally Posted by 71jeepster View Post
[img]http://s201.photobucket.com/albums/aa167/smiley_tiger/OSTC/IMG_0081.jpg[imgl]
I believe they are just 7" extended TJ flares put on the XJ and painted to match.
Page generated in 0.56895 seconds with 83 queries
