SBC YJ Swap Parts - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 1st, 2007, 05:47 PM   #1
RANGER_DANGER
Now I Got a V8!
RANGER_DANGER's Avatar
Send a message via AIM to RANGER_DANGER
Default SBC YJ Swap Parts
I need:
Engine mounts
Swap Radiator
Headers
Adaptors (305-AMC Th400 tranny) (Th400 Tranny to ??? transfercase)
Possibly front Axle
Let me know if you have any of these things!
RANGER_DANGER is offline
Old December 1st, 2007, 08:56 PM   #2
BigBlkYJ 355
U-Joints Fear Me
BigBlkYJ 355's Avatar
I used the advance adapters mounts that weld in and had really good luck with those. I used a 6 cylinder rad. with dual electric fans, which also works out really nice since it bolts right in place.
BigBlkYJ 355 is offline
Old December 1st, 2007, 10:23 PM   #3
RANGER_DANGER
Now I Got a V8!
Yeah, I was hoping someone had some from an abandoned project or something and I think I found the radiator I want to use.
Old December 2nd, 2007, 11:30 PM   #4
PavementPounder
PavementPounder's Avatar
If you're running a Chevy motor and you're not going to use a Quadratrac transfer case, there is no reason for you to use an AMC TH400 at all. Use a Chevy TH400. No adapter at the engine, and it'll already have a factory NP-pattern on the output if it wasn't robbed.
If you already have a fresh or built AMC TH400, get a dead Chevy and swap the housing and tail. You'll still save money.
This sounds like a lot of trouble to install a 305. I believe CC has been down this path before.
PavementPounder is offline
Old December 3rd, 2007, 07:02 AM   #5
RANGER_DANGER
Now I Got a V8!
It really depends on whether I can have the adapters made or not. I'm not going to spend 300 dollars on a piece of aluminum with holes drilled in it.
Page generated in 0.21810 seconds with 38 queries
