98 Polaris Scrambler, 2-stroke 400 help? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 29th, 2007, 04:27 PM   #1
03hemisilver
Pres MI Dodgetruckworld
03hemisilver's Avatar
Default 98 Polaris Scrambler, 2-stroke 400 help?
I have a 98 Scrambler 400, 2-stroke, put Boyeson reeds, and a dial-a-jet on it and it won't run for shiot.
I've adjusted the dial-a-jet down to where it shouldn't affect it, but still won't go very fast, in my opinion. Before I adjusted down, it ran okay, but would get to end of straightaway and bog down in the turn, then I'd wait for it to "wind up" and it'd take off? As if it's flooded and finally cleared it to take off again?
Has a FMF Fatty pipe and silencer on it. Stock bore, as far as I know.
Starts right up, first pull (rope start) but no speed?
Anyone have stock carb settings? I have two Chilton's but they only want to list 4-stroke specs
Ideas?
80 CJ frame, YJ body, 304 cid, 4" lift, 35"s, 4.10's, locked, 8K winch, garage queen
2012 F150 4x4 Lariat Supercrew Ecoboost
03hemisilver is offline   Reply With Quote
Old November 29th, 2007, 06:53 PM   #2
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
I can get you the carb specs tomorrow at work.
I would pull the spark plug and see if you are rich (black) or lean (bright white). The correct color should be a light brown.
I would look at your secondary clutch as well. Worn buttons can cause the clutch to stick and create a bog as well as reduced speed.
Old November 29th, 2007, 09:12 PM   #3
03hemisilver
Brand new clutch kit and replaced the buttons cause they were worn down......I put a bunch a new crap on this thing and haven't ridden it since cause I can't get it set up right
Old November 30th, 2007, 08:32 AM   #4
Motor Slut
Motor Slut's Avatar
ok the stock jetting is
+80*F 210 main 1.5 turns on the air screw
40-80*F 230 main 1.5 turns
0-40*F 250 main 1.0 turns
they came with a 230 main and 35 pilot from the factory.
Old November 30th, 2007, 08:59 AM   #5
03hemisilver
Thank You Motor Slut
Old December 14th, 2007, 11:08 AM   #6
fsumotorhead
N8KVB
fsumotorhead's Avatar
Did you ever get this going?
I have a good friend in Belleville I think he lives off Clarke Rd and we go riding once in a while, if your interested we will probably go out after Christmas.
Old December 14th, 2007, 01:47 PM   #7
03hemisilver
Nah, haven't gotten back to it. I've got a couple other quads ready to go. I'll PM ya.
Old December 16th, 2007, 01:11 AM   #8
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
pm me if you cant figure it out im not to far away. got somewhere to ride out there?
Old December 25th, 2007, 11:32 AM   #9
Golden
Full Size Chevy
www.gen3usa.com
You will not find a more knowledgeable group of gen 3 Polaris enthusiasts around.
Golden is offline   Reply With Quote
Old December 25th, 2007, 12:55 PM   #10
03hemisilver
Thanks for the notice on the site Golden
Old January 18th, 2008, 11:05 AM   #11
buddha
playing life by 'ear'
buddha's Avatar
hey 03hemidude,
ever get that polaris going?
:stan3:
buddha is offline   Reply With Quote
Page generated in 0.26092 seconds with 56 queries
