herculiner-ing a jeep - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 28th, 2007, 06:42 PM   #1
MudnCJ
countrybythegraceofgod
MudnCJ's Avatar
Default herculiner-ing a jeep
ive got a 93 jeep cherokee that im thinking of herculining. planning on doing thw whole thing in the red hurculiner. anybody have any experience with this? how long it took, prep work, difficulties, suggestions?
thanks for the help,
tj
MudnCJ is offline   Reply With Quote
Old November 28th, 2007, 06:53 PM   #2
Toivo
Feel lucky?
Toivo's Avatar
Read the directions.
A whole gallon won't do it.
Prep, prep, prep. And use the cleaner they tell you to or it won't have good adhesion.
(I did my XJ interior)
Old November 28th, 2007, 07:00 PM   #3
84Scrambler
Just watch your hootus. (google it)
Old November 28th, 2007, 07:03 PM   #4
Toivo
Feel lucky?
Toivo's Avatar
lol
Old November 28th, 2007, 07:05 PM   #5
chris1044
chris1044's Avatar
use durabak....herc isn't as nice IMO
Old November 28th, 2007, 07:13 PM   #6
DuffMan
Your Message Here
DuffMan's Avatar
X2
Durabak is UV-stabilized - Herc is not. Durabak comes in textured and smooth.
Just follow the directions, use the specified solvent, and prep, prep, prep.
Old November 28th, 2007, 07:21 PM   #7
Icebreaker88
Icebreaker88's Avatar
Originally Posted by DuffMan View Post
X2
X2 I used the Durabak smooth blue on my Bronco.
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline   Reply With Quote
Old November 28th, 2007, 07:31 PM   #8
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I ordered Durabak for the XJ yesterday.
I was impressed with the 8 years I had Durabak on the outside of the YJ.
Old November 28th, 2007, 08:04 PM   #9
MudnCJ
MudnCJ's Avatar
any idea how many gallons are needed to do the entire jeep?
Old November 29th, 2007, 10:48 AM   #10
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I would think 2 for good coverage and several coats.
Old November 29th, 2007, 11:21 AM   #11
General Lee
Slice of Starsage Anyone?
General Lee's Avatar
Send a message via AIM to General Lee
I did 2.5 coats on the interior of the old Teej with one gallon of herculiner.
As far as prep goes...I really didn't do that much...(sanded the rust and wiped the surfaces down with acetone). [NOT THAT I'M ADVISING TO TAKE THE SLACKER APPROACH, AS IT DOESN'T ALWAYS TURN OUT SO GOOD!!!]
I also did it in one night (got home from work, started at 5:30pmish, finished in the early amish then went to work).
Anywho, it lasted for the couple years I had it before I sold it.
General Lee is offline   Reply With Quote
Old November 29th, 2007, 11:33 AM   #12
BMFmike
meh.
BMFmike's Avatar
My Durabak on my JCR sliders lasted about a week... I am not happy with it at all, I sanded every single piece by hand for nearly 4 hours... Durabak said I used to fine of sandpaper and now I am out over $100 dollars.
Old November 29th, 2007, 05:19 PM   #13
Fraser
Fraser's Avatar
how fine of paper did you use?
Old November 29th, 2007, 05:31 PM   #14
Chris99XJ
If It Aint ruf It Aint Me
Chris99XJ's Avatar
I have been having trouble keeping my stuff on my JCR slidders too, I have re done them 2 times now, im sure ill hit them again in the spring. I know its not the steel JCR uses. i think it is the location of the sliders, always getting hit from rocks off of the tires.
Chris99XJ is offline   Reply With Quote
Old November 29th, 2007, 05:56 PM   #15
AmmoWagon
NO SMOKING 50 FEET
AmmoWagon's Avatar
Used 40 grit and a steel brush wheel on mine. Cleaned it using the recommended cleaner. Half gallon for one thick coat on the outside on the CJ. I rolled on the hood and got a cheap sprayer from harbor freight and sprayed the rest (spraying actually looks 10X better and took about 25 min). Worked great, but did run a little. The more coats the better. Just remember not to let it dry completely between coats. I do like the idea of the smoothness of the durabak. Herc is very rough, but tough as hell...
AmmoWagon is offline   Reply With Quote
Old February 29th, 2008, 03:56 PM   #16
snodevil
snodevil's Avatar
Location: Berkley, MI 48072 / Indian River, MI 49749 (cottage)
Send a message via AIM to snodevil Send a message via MSN to snodevil
Used one gallon of herc on my tj and got two good coats out of it. happy so far. Would think you would need two gallons for xj... maybe one gallon and one quart, but with the cost of the quart you may as well just get two gallons and put it on thick. If it chips or comes off then I think they will usually send you a free quart to touch it up.
x3 good prep is key, keep a rag soaked in thinner handy for quick clean ups also. Don't get it on cloth seats either.
snodevil is offline   Reply With Quote
Old March 2nd, 2008, 03:54 AM   #17
scorpiansniper
engine / paint tech
scorpiansniper's Avatar
Send a message via AIM to scorpiansniper
i did my 95 yj in black herculiner and im an experienced painter. i put 2 coats on with one gallon it comes with a green scotch brite you can use this but you gotta scuff the paint good cause it wont bond good to reg paint finish. i would also cover bare metal. i would use wax and grease remover. also dont plan on using any brushes or rollers after it dries so try to get it done in a couple coats. since your doin a xj you prob need a couple gallons
scorpiansniper is offline   Reply With Quote
Old March 4th, 2008, 07:27 PM   #18
Grunto
Grunto's Avatar
Send a message via AIM to Grunto
I did my rockers with Herculiner. Took a couple nights during a weekend to prep then the 3rd night I was up all night applying it. It looked great at first, but it does eventually fade.
It's all about the prep work.
Attachment 21718
Attachment 21719
Grunto is offline   Reply With Quote
Old March 4th, 2008, 08:44 PM   #19
Arnie897
y=mx+b
Arnie897's Avatar
Send a message via AIM to Arnie897
I have met that guy. Good man. As far as I know all has been taken care of.
Arnie897 is offline   Reply With Quote
Old March 4th, 2008, 09:46 PM   #20
Redneck4x4
Redneck4x4's Avatar
I did my CJ tub with 2 coats of herculiner and it took 1 gallon. I topped it with Herculiners UV protectant and it looks great after 2 years. I agree that good prep work is the most important part, scuff everything good.
Redneck4x4 is offline   Reply With Quote
Page generated in 0.68957 seconds with 83 queries
