spoa lift kit - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 28th, 2007, 02:12 PM   #1
905darryl
Default spoa lift kit
I am hoping to get some info on wich kit to go with. I would like to get 31x10.5 under my 1985 samurai.any help would be appreciated
905darryl is offline   Reply With Quote
Old November 28th, 2007, 05:27 PM   #2
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Im not sure what kit i have but i have 31x10.5's and missing link shackles and it does awesome offroad.
I dont think theres a bad kit since its all stock spings just spring perches and hardware
Old November 28th, 2007, 06:23 PM   #3
ouchman
ouchman's Avatar
Send a message via Yahoo to ouchman Send a message via Skype™ to ouchman
spring over
support the sport- www.GLFWDA.org - member
Dear Travelers,
You won't see London and you won't see France, until we see your underpants!
Sincerely, TSA Officers
ouchman is offline   Reply With Quote
Old November 28th, 2007, 09:49 PM   #4
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
Originally Posted by ouchman View Post
spring over
either im reading this wrong or hes asking for what spring over kit? idk
Old November 29th, 2007, 11:28 AM   #5
scottie
Eye candy
scottie's Avatar
any of them, they are all pretty much the same, if you want it quick, don't get it from Rocky-road, and trail-tough is good but it takes 9 business days once UPS gets it for it to make it to michigan.
Old December 2nd, 2007, 06:23 AM   #6
905darryl
Default thank you scottie
trail tough looks good and theit prices are the most reasonable so far thanks for the info.
Old December 2nd, 2007, 12:16 PM   #7
jimmyroyse
webwheeler
jimmyroyse's Avatar
another place to check,
rockrat can get or has just about everything too;
http://www.rock4xfabrication.com/
and since you are in Canada eh;
http://www.zookpower.ca/mainpage.html
jimmyroyse is offline   Reply With Quote
Old December 2nd, 2007, 04:01 PM   #8
motrctyman
Just The Spouse's spouse
motrctyman's Avatar
Can you fit 31's under a SPOA (4.5") and 33's under a 6" lift? Any trimming needed?
motrctyman is offline   Reply With Quote
Old December 2nd, 2007, 07:38 PM   #9
swampjeep
Swamp Stomper
swampjeep's Avatar
I believe yes and no
my Samy has a 4" lift I believe, sits about the same as one with a SPOA, 31's fit nice, 33's fit but rub alot in turns and flex, I dont' know it 2" more lift would stop all the hitting in flex.
but go buy it
:tonka:
swampjeep is offline   Reply With Quote
Old December 2nd, 2007, 08:14 PM   #10
A4X4SPIT
A4X4SPIT's Avatar
Ive lifted a bunch of samis by spring over I usually use 5" lift spring perches U bolts/plates lower shock mounts longer shocks longer brake lines drive shaft spacers and a z drag link or drop pitman arm or a high steer kit to get 33 to fit I cheet the ft axle foward by moving center pin hole in perch /spring plate back a inch or 1.5 "s back
(33 s & no ft rub) I also turn the rear helper spring over and have added a extra leaf to ft to help keep the flat springs from reversing arching
http://www.sky-manufacturing.com/
A4X4SPIT is offline   Reply With Quote
Page generated in 0.32838 seconds with 53 queries
