SOLD - AAM 1050 FF rear, 4.10, 1800 miles, no brakes - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 27th, 2007, 10:37 PM   #1
PavementPounder
PavementPounder's Avatar
Talking SOLD - AAM 1050 FF rear, 4.10, 1800 miles, no brakes
AAM 1050 from a 2001 Chevy 2500 HD. 1800 miles. One bent shock mount. Probably got bent at the dealership and warrantied. 10.5" ring, 4.10 gears, ~68" WMS. Its been garage-kept since at least sometime in 2003 or 2004 when I began working on the guy that was sitting on it.
This axle is the descendant of the GM Corporate 14-bolt. Its not the same exact axle, although people will still refer to them as such and there are probably some common parts, such as bearings, seals, etc. The housing is an improved casting, which you can easily see by way of all the ribs that are not present on 14-bolts.
Its currently in the back of my truck and can be delivered around the Metro Detroit area (as pictured).
The other two pics are from before the hardware was removed. I'm told the inner "perches" are bumpstops.
$400
SOLD.
PavementPounder is offline
Old November 27th, 2007, 10:39 PM   #2
chevytaHOE5674
Send a message via AIM to chevytaHOE5674
you sure on the gear ratio? Never seen a 3.54 2000 era truck. usually 3.73
chevytaHOE5674 is offline
Old November 27th, 2007, 10:46 PM   #3
PavementPounder
No. It could very well be 3.73. Its not 4.10, though and its too cold to go outside and spin it right now.
Is there a code stamped on it someplace?
Old November 27th, 2007, 10:51 PM   #4
chevytaHOE5674
There might be a tag on it, if not got to spin it, or pull the cover. If it isn't 4.10 though it is most likely 3.73 the standard gm ratio.
Old November 29th, 2007, 06:39 PM   #5
PavementPounder
Yup, I'm retarded. Its 4.10. I got it confused with the 2nd axle I bought from the same guy.
Old December 3rd, 2007, 06:56 PM   #6
bryanbryan89x
bryanbryan89x's Avatar
I am kinda interested in putting this in my samurai. Do you know if it is the 1355 or 1410 yoke?
bryanbryan89x is offline
Old December 3rd, 2007, 08:11 PM   #7
PavementPounder
I don't happen to know the joint size, but I'll try to figure it out.
Old December 3rd, 2007, 08:14 PM   #8
lt1yj
That looks the same as the axle that was under my '97 3/4 ton Suburban only it had drums. I have a 2001 model "14 bolt" that I pulled the diff and pinion out and stuck them in a early 90's vintage 14 bolt so I can verify that the diff is interchangeable. I didn't pull the gear set so I can't verify the carriers are identical but I couldn't tell any visual difference.
Might be worth looking into.
BTW I have 1 full set of brakes for this and a set of caliper brackets and E brake setup if someone needs them to "complete" this axle.
lt1yj is offline
Old December 3rd, 2007, 08:28 PM   #9
PavementPounder
I was discussing this with Jason at UORC today, as he began comparing the parts lists. Yes, a lot of it is still interchangeable, but not everything.
As for the brake setup, getting another setup like this one was the original plan. Upon investigating with Koz there were at least 4 different brake configurations that were found when looking at 1050's at the salvage yards and we weren't going to go hauling the axle everywhere to compare them. I wouldn't know how to go about verifying yours are right other than test fitting the parts.
Old December 5th, 2007, 11:40 AM   #10
PavementPounder
Deal pending today.
Old December 6th, 2007, 09:05 AM   #11
PavementPounder
Sold.
Old December 6th, 2007, 01:20 PM   #12
Tikiclub2
Did anyone verify that 'old 14 bolt' diff and pinion are swappable?
Tikiclub2 is offline
Old December 6th, 2007, 01:28 PM   #13
PavementPounder
LT1YJ said so, but I don't know if the buyer looked into that or even cared. The build date on the inside of the diff was 02/2001.
Page generated in 0.39823 seconds with 62 queries
