Dodge vs Chevy Dana 60 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 27th, 2007, 07:45 PM   #1
kickstand
circling the drain
kickstand's Avatar
Default Dodge vs Chevy Dana 60
Is there any reason that a chevy is more desireable then a dodge?
Both are Kingpin axles.
the only real difference I see is the dodge has 2.5" wide spring perches and the chevy is 3" wide.
Am I missing something?
Old November 27th, 2007, 08:09 PM   #2
snocross2xtremes
snocross2xtremes's Avatar
um the 87 up dodge and chevy ones are the same axle from what i was told.
Old November 27th, 2007, 08:13 PM   #3
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
external hubs equal piece of crap and costly to upgrade i got hosed when i bought my first 60 it was a chevy bom number but some put dodge outers on it.
Old November 27th, 2007, 08:19 PM   #4
kickstand
circling the drain
kickstand's Avatar
I forgot about that, but can they really be that bad? I mean I am not building a comp buggy.
Old November 27th, 2007, 08:19 PM   #5
hosejockey4506
Visiting Admin
they suck
Old November 28th, 2007, 10:54 AM   #6
liv2mx
i like jungle gym's.
liv2mx's Avatar
but what if he could buy the whole truck part it out and basicly get the axles for a couple hundred??? worth it or not?
Old November 28th, 2007, 11:03 AM   #7
IDIeselman
IDIeselman's Avatar
If it's under a dodge make sure it's not a (61) I don't know about the chevy's but 61's are common under the dodge's.
Old November 28th, 2007, 11:19 AM   #8
kickstand
circling the drain
kickstand's Avatar
Talking older style kingpin axles. Not a newer unit bearing disconnect axle.
Old November 28th, 2007, 11:20 AM   #9
kickstand
circling the drain
kickstand's Avatar
Yes, that is something to look out for with the dodges, but simply getting the build number before purchase will take care of that.
Other then the added cost to switch to 35 spline axles over the cost of switching the chevy to 35 spline I dont see any disadvantage, I willhave to look into the cost differences.
Old November 28th, 2007, 11:24 AM   #10
95geo
newbie
95geo's Avatar
which ever one you dont want pass the info on to me
please
Old November 28th, 2007, 02:36 PM   #11
liv2mx
liv2mx's Avatar
please
i pm'd you the info on the one i had a line on.
Old November 28th, 2007, 02:40 PM   #12
thall
also, probably the biggest difference to a lot of people is the width. the dodge's are few inches narrower. i don't remember the exact width, but i think it is 2-3".
thall is offline   Reply With Quote
Old November 28th, 2007, 03:57 PM   #13
95geo
newbie
95geo's Avatar
Ill spend ~1/2 of what the truck would have cost and I also dont want to deal with the rest of the truck after the axle is gone.
Old November 28th, 2007, 05:07 PM   #14
liv2mx
liv2mx's Avatar
yep i dont want to deal w it eather. chevy is the way to go.if i did not need drivers drop, i would have a chevy 60 in my jeep. the shafts do not neck down on the chevy they do on the ford. does the dodge neck down?
Old November 28th, 2007, 08:34 PM   #15
PavementPounder
PavementPounder's Avatar
Just go buy Mr. Green's axles.
Old November 29th, 2007, 09:12 AM   #16
redleg
The 61 was ude from 89- 91.5 on automatic diesels with no overdrive or inner cooler. It'll have a 61 on the top pass side of the pic, if I remember right. Also the gear tag will say 3.07.
redleg is offline   Reply With Quote
Old November 30th, 2007, 06:01 AM   #17
halfgassed
halfgassed's Avatar
not sure if ya got my return pm on misfits, but one of hte axels we were disscussing had drive flanges, the other had lockouts. I know the external style lockouts a failure prone.
If it were me I'd take the one that has the drive flanges on it, run it till ya can convert it over to internal style hubs. For what ya'd be getting the axel for you could convert it over and still be under 1000.
halfgassed is offline   Reply With Quote
Page generated in 0.31934 seconds with 74 queries
