stick welder help (OMG it works now!!!, response #28) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 24th, 2007, 10:27 PM   #1
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
Default stick welder help (OMG it works now!!!, response #28)
I cannot get this darn thing to work right.. It keeps just welding the stick to the part I'm working on and won't hold a constant arc.
7018 rod. I'm welding a 1/4" round piece of weld steel to a body mount. took a grinder and cleaned up all the rust as well at a spot for the clamp.
I've tried all sorts of angles - flat to nearly 90°, push, pull, light pressure, heavy pressure, more power, less power, moved the clamp around to the bar itself. I cannot get this to work... I had a welding class at Ferris where we stick welded and I think it stuck twice, both times being accidentaly touching the piece.
Gotta pack it up by tomorrow morning, so hopefully I'll get some quick responses...
*edit, almost forgot
It's not melting the flux around the electrode for some reason, I have to keep cutting it away because the electrode melts away inside leaving a short hollow tube of flux.
Old November 24th, 2007, 10:29 PM   #2
454 jeep
454 jeep's Avatar
Sounds like your welding rod has seen some moisture. Try a different one.
454 jeep is offline   Reply With Quote
Old November 24th, 2007, 10:32 PM   #3
Captain Ledd
Ranger Addiction?
allright, I'll give that a shot. That'd kinda bum me out because it's a brand new package that I opened earlier tonight...
Old November 24th, 2007, 10:53 PM   #4
Motor Slut
I put the Ick in Dick.
Motor Slut's Avatar
A 7018 rod ideally should be baked before use. You can preheat them in the oven at around 300-350* for about 20 minutes to get the moisture out.
The 7018 is a low hydrogen rod so when it gets wet it doesn't work right.
Old November 24th, 2007, 11:05 PM   #5
Pre4runner
Bike Dude
Pre4runner's Avatar
x2
I think i'm going to put an old oven in my garage.... I'm always baking parts and welding rods
Old November 24th, 2007, 11:07 PM   #6
Captain Ledd
Ranger Addiction?
ooohhhh... allright, I'll try that.
I did try another rod, 3 actually. One welded nice for about 3/4 of a second and then did the same thing.
Man.. I was recommended these as a good all around weld just about anything rod...
Well that still a little more reassuring motor slut and pre4runner. *goes to preheat the oven. never thought 4 little hangars would be so much trouble..
and I can cook some chicken afterward
Old November 24th, 2007, 11:49 PM   #7
Captain Ledd
Ranger Addiction?
nope. same thing. gonna put them in for another 20min @ 350...
Old November 24th, 2007, 11:50 PM   #8
Pre4runner
Bike Dude
Pre4runner's Avatar
also what diameter rod? and how many amps are you trying?
Old November 25th, 2007, 12:02 AM   #9
Captain Ledd
Ranger Addiction?
yeah, was just looking that up actually. Just remembered that I never sold back my welding book so I dug around and found that.
3/32 rod. 125 amps. which is high I guess, book says 70-100 for that kind of rod. I had it set at 125, which supposedly is better suited for the next size rod.
Gonna try that after this round of baking is done. It's a 240 welder.
Old November 25th, 2007, 12:07 AM   #10
454 jeep
454 jeep's Avatar
Round 2= Farmers rod...Good old 6011
Old November 25th, 2007, 12:16 AM   #11
Captain Ledd
Ranger Addiction?
thats a number thats familiar.. I may just go ahead and try some of that next weekend I particularly recall welding with that one.
As I said before, I was recommended this as a easy, weld most anything, general garage use rod...
Old November 25th, 2007, 12:20 AM   #12
nick_n_ii
nick_n_ii's Avatar
Send a message via Yahoo to nick_n_ii
I alway have good luck with 6013 3/32 Rod. I have the same issues with 7018 rod....
nick_n_ii is offline   Reply With Quote
Old November 25th, 2007, 12:37 AM   #13
Captain Ledd
Ranger Addiction?
one last thing, would switching the leads make a difference with this rod? the welder doesn't have a + and - and I can't recall which is which.. I think I had this problem with one rod from class now that I think about it.. damn.. I should really think more. This hindsight crap is getting old. must be because I'm frustrated and it's late..
too hungry now, I'm gonna try switching the leads later...
Old November 25th, 2007, 12:48 AM   #14
fittergirl
Bird is my bitch
fittergirl's Avatar
The 6011 is better suited for an all purpose rod, you will get better penetration. At work we weld root and hot passes with 6010 (pretty much the same as 6011) and cover with the 7018.
Try switching the polarity if you think the leads might be wrong. Usually I can tell by sound when the leads are mixed up.
fittergirl is offline   Reply With Quote
Old November 25th, 2007, 01:26 AM   #15
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
I don't know a ton about stick welding. But I do know 125amps is too high for 3/32 rod.
JcrOffroad
Zoom Zoom!
Old November 25th, 2007, 02:22 AM   #16
Captain Ledd
Ranger Addiction?
well, I didn't, not owning a welder makes me a little out of practice.
Switching leads didn't help either... I'll pick up some 6011 and see what I can do next weekend...
Old November 25th, 2007, 09:10 AM   #17
jmdzuk
jmdzuk's Avatar
7018 is a drag rod don't hold arc lay it right on the work and drag .
jmdzuk is offline   Reply With Quote
Old November 25th, 2007, 10:02 AM   #18
Captain Ledd
Ranger Addiction?
yeah I was dragging actually. Of course by the time I probably got everything set up right it's was so screwed up and lumpy I still couldn't start it. I have to leave for college in an hour or two. I'm pretty much done for now..
Old November 25th, 2007, 06:17 PM   #19
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
I wasn't trying to insult you.
JcrOffroad
Zoom Zoom!
Old November 25th, 2007, 06:31 PM   #20
curt1656
Praise the lowered
curt1656's Avatar
I got a stick welder for free from a school that was throwing it out cause it was doing the same thing you're describing.Took the cover housing off,repaired the corroded wire terminals on the plug supply voltage,it worked great after that.
Page generated in 0.47154 seconds with 83 queries
