Removing RTV - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 14th, 2006, 09:53 AM   #1
amc78cj7
amc78cj7's Avatar
Default Removing RTV
OK, only slightly gayer than the "how to remove stickers" question.
I have struggled with this for years. I absolutely hate removing RTV from diff covers, t-case halves, etc. The only thing that works, and not well, is to hit it with brake cleaner and start scraping with a paint scraper. However, this takes FOREVER to get it all off.
Is there a better way to build a mousetrap?
I'm not quoting idiots who promote unsafe recovery strap techniques anymore. :miff:
amc78cj7 is offline   Reply With Quote
Old March 14th, 2006, 10:01 AM   #2
Bones
Bones's Avatar
wirewheel and an angle grinder, then clean the inside of the diff with brake cleaner
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old March 14th, 2006, 10:02 AM   #3
Sandals
Fucking Zen as Shit
Sandals's Avatar
thats the best way i've found..... f'in RTV is an evil necessity
Old March 14th, 2006, 10:08 AM   #4
cornfed
I have an avatar. Yippee.
cornfed's Avatar
90*/right angle/angle die grinder using 3M bristle discs
Old March 14th, 2006, 11:02 AM   #5
shawn
Resident HVAC/R Jambi
shawn's Avatar
I leave it and put more on top of it.
Old March 14th, 2006, 11:23 AM   #6
SS
Bananarama!
SS's Avatar
Gasket Material Dissolving Gel
Located in front of the parts counter at your local murrays!
-Jer
Old March 14th, 2006, 12:12 PM   #7
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
at the dealer I had a bench grinder on a pedistal and it had a 8" wire wheel. it was the shit for taking off rtv, it didn't care how thick or thin. as for the axles and engine blocks I use scotch brite pads that go in a die grinder, check a real parts store for them.
Yetti
Old March 14th, 2006, 12:19 PM   #8
cornfed
cornfed's Avatar
Maybe it's a preference thing, but if you haven't tried the bristle discs give 'em a whirl. They last a LOT longer than the scotch brite discs and don't get gunked up when things get messy. The entire disc is made from the abrasive so you can take 'em down to the mandrel. For ~$15 you can get a 2" 6-disc kit with three different grits.
Page generated in 0.20353 seconds with 47 queries
