1991 F-250 Shifting Funny!!!!!!. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 23rd, 2007, 03:58 PM   #1
guest
Send a message via AIM to guest
Default 1991 F-250 Shifting Funny!!!!!!.
My cousin has nice 1991 F-250 Regular Cab Long Bed 4x4. He just bought Bushwacker Cut out flares and 36-13.50-16.5 Super Swapmer Irok Tires for it. All Brand New. But he was driving it today to work and got on it hard and it would'nt shift into second gear. Its just sticking in the gears. It shifts fine and works fine if he drives it easy though. The truck has a Big 460 BB Motor in. My guess is a C6 transmission but I havw no clue. Anyone got any ideas????? Think a simple transmission flush could be fix it?
Thanks, A.J. Hall!.
guest is offline   Reply With Quote
Old November 23rd, 2007, 04:01 PM   #2
FORD FLARESIDE
Headed to Nationals 2017!
FORD FLARESIDE's Avatar
Thanks, A.J. Hall!.
E04D Tranny, I'm having the same problem right now,................there is an electronic controller on the drivers side of the transmission, I believe this is where my problem is. You might want to start checking there.
Old November 23rd, 2007, 04:02 PM   #3
guest
K Thanks got any idea how much thats gonna cost and how hard it is to install?
Old November 23rd, 2007, 04:03 PM   #4
FORD FLARESIDE
I haven't pulled it yet, but will tonight.............I'm guessing around $100
Old November 23rd, 2007, 04:07 PM   #5
guest
hmm. well after you pull it do you think you could tell me how hard it was and the price and such please? Do you also have a 460?
Old November 23rd, 2007, 04:08 PM   #6
FORD FLARESIDE
No I don't have a 460, but I do have the E04D.
Old November 23rd, 2007, 04:12 PM   #7
guest
O ok. That 460 is a hell of a motor. Your sure it would have a E04D in it. It came factory with the Big Block 460.
Old November 23rd, 2007, 04:19 PM   #8
FORD FLARESIDE
If it is a 1990, that is probably what is in it............Ford put the E04d behind the 302 all the way up to the diesel, ........the case is different between big block and small block.
They may have used the SS planetary gears behind the 460 instead of the alluminum.
Old November 23rd, 2007, 04:35 PM   #9
guest
Do you know of any place that I could look to see what kind of trans it is? Like somewhere on it.
Old November 23rd, 2007, 06:32 PM   #10
FORD FLARESIDE
Does it look like this?
http://www.dieselpowermag.com/tech/f.../photo_01.html
Old November 23rd, 2007, 06:42 PM   #11
guest
Yea that looks about right!!!.
Old November 24th, 2007, 07:53 AM   #12
s_burby
just floor it!
s_burby's Avatar
If it has first, second, drive then it is a C-6. If it has an OD then it is an E4OD.
Might be a kick down cable? but i never hade any trouble with my C-6
s_burby is offline   Reply With Quote
Old November 24th, 2007, 02:44 PM   #13
guest
Its has P,R,N,D,2,1, Then push button on and off overdrive.
Old November 24th, 2007, 03:21 PM   #14
Chiefwoohaw
Pokerob is my B*tch!
Chiefwoohaw's Avatar
E4od
Old November 24th, 2007, 03:27 PM   #15
guest
Thanks.
Old November 24th, 2007, 06:37 PM   #16
FORD FLARESIDE
I was wrong on the issue with mine, just got inside from the garage..........the problems I have been having have all been caused by the Pivot bolt on the T-Case linkage.............The bolt had loosened up and, was causing slop in the linkage.
Check this part.
Old November 25th, 2007, 11:43 AM   #17
Dieselphreak2000
Somehow still alive..
Dieselphreak2000's Avatar
That's fairly common. I've seen it happen on quite a few trucks.
Dieselphreak2000 is offline   Reply With Quote
Old November 25th, 2007, 02:30 PM   #18
guest
I dont get it? got any pics of this bolt? or clues where it would be located. Thank you. please.
Old November 25th, 2007, 07:33 PM   #19
bj house
bj house's Avatar
There is usually only one pivot bolt on the transfer case linkgage. It's large and has a metallic looking color to it.
Old November 25th, 2007, 08:32 PM   #20
guest
O shit.lol. on the linkage??
Page generated in 0.34783 seconds with 83 queries
