limited slip instal help needed. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 23rd, 2007, 03:50 PM   #1
luvitmyjeep
broken
luvitmyjeep's Avatar
Default limited slip instal help needed.
are the spyder gears sappost to move freely in a factory tracloc?
thanks
luvitmyjeep is offline   Reply With Quote
Old November 23rd, 2007, 04:49 PM   #2
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Until one wheel spins more than the other so it locks up, yes.
Old November 23rd, 2007, 07:36 PM   #3
luvitmyjeep
broken
It's locked up in the carrier, out of the axel....this is normal?
Old November 23rd, 2007, 07:37 PM   #4
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
If you can move them by hand the frictions are wore out. If you are jacking up one tire off the ground and using "force" you can get it to spin but is still good. If it spins like and open than it is worn out and now an open carrier.
Old November 23rd, 2007, 07:38 PM   #5
KILLER"B"468
Yankabilly
you shouldn't be able to move them out of the axle with it on a work bench.
Old November 23rd, 2007, 08:18 PM   #6
luvitmyjeep
broken
thanks i was getting worried that i did all this for nothing!
Page generated in 0.20477 seconds with 41 queries
